Exhaust question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2008, 01:33 PM
Exhaust question
My car has 1-5/8" headers, 3" collectors, 3" H-pipe and dual 3" Flowmasters. Right now the motor is a H/C/I - 351W (N/A) making 400-420hp.
My question is - if I weld two 3" to 2-1/2" reducer pipes on the output of the two Flowmasters will my car lose power?
My other question is same exhaust set-up including the reducer pipes on the output of the Flowmasters but with a 418ci SBF (N/A) making 550hp at the crank?
The reasoning by this reducer pipes addition (?) is at WOT it's a friggin' cop magnet. Thanks everyone for your time.
Old 07-09-2008, 01:44 PM
Greg T's Avatar
www.krusinklassics.net
Pretty much anything is a cop magnet at WOT. Are you thinking that reducing 3" to 2.5" will make it quieter?? Uh, ...no.
Old 07-09-2008, 01:45 PM
Yeah - that's my thinking. I don't know alot about exhaust. I was hoping that dual 2-1/2" exhaust holes would be quieter than it's present dual 3" holes.
Old 07-09-2008, 02:07 PM
Greg T's Avatar
Wont make a bit of difference. Want quiet? Change mufflers or keep your foot out of it.
Old 07-09-2008, 02:11 PM
For a street engine, probably not. The reason is that the exhaust gases cool and contract as they move away from the engine. The muffler further reduces energy in the gases which not only quiets them but the process also cools and further contracts them. As the gases cool and contract inside a given pipe diameter they loose velocity. This can result in some amount of stagnation which will increase back pressure in the system. Reducing the pipe diameter behind the muffler will restore flow velocity of the cooling gases which will enhance getting the stuff out the rear and keeping the 1-5/8 pipes up front pulling harder on the valve.
1-5/8 pipes are suitable for a 350ish cid engine up to about 6000 rpm, they would prove to be too small on a 418. The 3 inch head pipes would be fine on the 418. For the 351 if mostly street driven, would be too large compared to the 1-5/8s headers, you get an immediate stall in the pipe with this. A 2-1/2 head pipe with a 2 inch H and 2-1/4 tail pipes would be a more effective solution.
Bogie
Old 07-13-2008, 09:15 AM
klx650sm2002's Avatar
Re: Exhaust question
Stupid question time, when you guys quote a diameter as 1-5/8 is that i.d. or o.d.
I have 1-5/8 i.d.(41.275mm) on my 650cc single with a 41mm pumper carb.
Clive W
Old 07-13-2008, 02:54 PM
techinspector1's Avatar
Wiki Edits: 326
Normally the o.d.
Old 07-13-2008, 03:09 PM
The Maintenance Geek
That is exactly what I have to do, but I drive by a police station
every morning, and they look at me, but I drive like a somewhat
responsible adult...
The only one that has complained is my neighbor...
K
4l60 Pump cover 3-4 Exhaust question blacklabzeke Transmission - Rearend 1 12-07-2007 05:58 PM
Exhaust question for super/turbo members jameskirk1 Engine 7 08-18-2005 07:58 PM
Exhaust Welding Question HARDEIGHT Engine 5 08-18-2005 02:18 AM
exhaust cut-outs question bigpapagun Hotrodding Basics 8 01-27-2005 04:01 PM
Pontiac 455 exhaust question leeralidak Engine 2 03-04-2004 01:40 AM
