exhaust question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2008, 09:59 AM
exhaust question
the kib i bought this car from had a set of hooker comp headder and 3" pipe on it
my question is he has 3" collectors joined together by what looks like arround 2" pipe from drivers side going to passenger side collector then after passenger collector he welded it to the 3" pipe
i need to know if it will make my car run like crap i think the kid was stupid but mabe there is a reason for this
please tell me if it is a good idea or bad idea
Old 07-14-2008, 11:20 AM
Sounds like you are describing an H pipe. Connecting each side together helps balance the exhaust pressure pulses and improves low/ mid range torque and helps quiet the exhaust, as well as changing the sound by taking out a lot of the pop sound.
Normally the crossover pipe is connected to the exhaust pipes about a foot behind the collector ends. The exact location is not critical because an engine runs at different rpms, so is installed for simplicity sake.
I have never seen a crossover pipe welded directly to a header collector.
Old 07-14-2008, 11:26 AM
SSedan64's Avatar
It's recommended to have the H-pipe as close to the collector as possible but I've never seen it connected to the collector either. Shouldn't be a problem though. May make removing the headers a real task.
Old 07-14-2008, 02:15 PM
im sorry i may have been misleading they re not welded he did put flanges on there where they bolt to the headders
my concern is the 2" pipe is from the dr side to pass side then connected to 3" pipe one pipe back to the muffler the 2 out is it ok to keep or do 3" all the way back ???
Old 07-15-2008, 12:19 AM
SSedan64's Avatar
Now I'm confused . Is this a 2 into 1 style exhaust? A 2" crossover from collectors to one 3" pipe to a single muffler & 3" pipe out the back?
Old 07-15-2008, 05:00 AM
Y-pipe
Shane
Old 07-15-2008, 11:49 AM
Everything is HAMMER!
Your for sure gonna want to move up to a properly sized y-pipe, my camaro has a 2.5" mandrel bent y-pipe, and thats even a little on the smallish side. Most of us thirdgen guys like to run 3" from the collector to the muffler out back. Check out the exhaust forum on thirdgen.org for sure.
4l60 Pump cover 3-4 Exhaust question blacklabzeke Transmission - Rearend 1 12-07-2007 04:58 PM
Exhaust tips CrazyRoyExhaustfreak Engine 0 10-29-2006 06:04 PM
Exhaust question for super/turbo members jameskirk1 Engine 7 08-18-2005 06:58 PM
Exhaust Welding Question HARDEIGHT Engine 5 08-18-2005 01:18 AM
exhaust cut-outs question bigpapagun Hotrodding Basics 8 01-27-2005 03:01 PM
