Exhaust questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2004, 09:12 PM
chevyman06's Avatar
Exhaust questions
hello everyone. I am about to install 2 forty series flowmaster mufflers on my pickup, and the mufflers have a 3 inch inlet and outlet, but my current setup uses a 3 1/2 inch pipe, could i just down size my pipe with an adapter? Or would that cause flow troubles? by the way this is my 2002 CHevy with a 6.0 Liter vortec engine. Thanks to all!
Old 10-26-2004, 11:18 PM
Neophyte's Avatar
I'm not superstitious
Last journal entry: Release catch for trunk lid pt.5
It will cause a flow restriction thereby a drop in performance. You should try to stay with the 3 1/2 diameter BUT check the internals of the muffler too so that also has the same diameter.
Old 10-26-2004, 11:48 PM
Siggy_Freud's Avatar
I dont believe it will create a drop in performance that you'd ever notice.
Your going to run dual 3.5 inch exhaust? If so thats way more than is needed for your setup. A little backpressure might do it some good.
Bringing history and technology together.
Old 10-26-2004, 11:53 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
3.5 inch exhaust on a 6.0, (~364c.i.) is freekin' huge! That thing must either be modified sick or have no torque. 2.75" is the biggest I'd use. But, how's that 3.5 inch work for ya?
Old 10-28-2004, 09:13 PM
chevyman06's Avatar
well the current exhaust is dualed to the muffler ( 2 cats before the muffler, i beleive that those are 3 1/2 inch pipes also) and 2 outlets out of the muffler, then they form a Y into 1 pipe, a 3 and 1/2 inch pipe. This is the stock system with the stock vortec muffler on.
