Exhaust Recommendation - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-11-2009, 09:34 PM
I had Flowmaster exhaust installed in my 1963 Chevy truck and I am finding it is a little too loud for my liking.
The engine is a 383 with 400hp+, if that is pertinent.
Any suggestions out these for an exhaust system which will be "quieter" and will not significantly impact performance?
Thanks
Old 12-11-2009, 10:07 PM
DoubleVision's Avatar
I recommend Dynomax turbo mufflers. Nice, deep tone at low rpm with quietness and they sound off nicely at WOT.
Old 12-12-2009, 12:00 AM
JeffB's Avatar
Did they run a balance tube or X pipe when they installed it? where are the mufflers located? If they are under the cab they will resonate a lot,I had that problem with a '65 C10.A quality insulation will make a major difference too.
Old 12-12-2009, 01:31 AM
F-BIRD'88's Avatar
Yada Yada Yada
The interior sound resonance caused by a classic Flowmaster muffler gets old after a while.
Change to a "tri flow" style turbo muffler design . 2.5" pipes. Full tail pipes exiting at the rear bumper. A crossover pipe/balance pipe that connects the two exhaust banks of a V8 helps too.
Do a google search for Helmholtz filter, helmholtz resonator as it refers to exhaust system sound resonance supression.
Need Header Recommendation eyecantdrive55 Engine 5 04-26-2007 10:23 AM
exhaust crossover ljjjrome Engine 8 04-03-2007 12:22 AM
GM fast burn heads batman09 Engine 1 10-26-2004 09:32 AM
Exhaust formulas vs. computer programs Mean Dean Introduce Yourself 1 07-13-2004 12:26 PM
Exhaust Manifold Leak???!!!?! ponybuster Engine 4 09-17-2003 02:41 PM
