Exhaust setup enquiry - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2009, 08:33 AM
Last journal entry: Inch each day is ok for me...lol
I would like some help figure this out. I got old Mr. Gasket headers with 3'' collectors and pipes going to turbo mufflers 2.5'' all the way through on my sbc. My question was what is the horsepower rating for 2.5'' pipe . I am using straight headers with no crossover or h pipe. I figure if dyno 2003 is right, I should be close to 500hp.
Old 01-20-2009, 09:38 AM
your journal says you have a Edelbrock RPM street cam and double hump heads...
very likely you entered something wrong in the DD to come up with 500HP from that 350 combo...
here's a Dynomax chart that shows your 2.5" is the normal/correct size
if the car has "street friendly" tall rear gears,,,adding a "H" exhaust balance pipe will likely make it more low rpms responsive
Old 01-20-2009, 12:15 PM
Thanks for the info
Great... You would know where I could find a flow file for a 65 camel hump heads???
Old 01-21-2009, 12:27 PM
jv,
there are a some stock Chevy head flow articles somewhere in the engine section of the "Knowledge Base" link at the top of this page....
post a new thread question titled: "stock double hump heads flow numbers????"
sorry, I can't help ya....
but just for reference:
stock 461 fuelie heads=44I/41E flow efficiency %
stock 96 Vortec heads=48I/51E flow efficiency
(both with the same valve sizes)
Supercharged exhaust question Pre-Tuner Engine 18 06-27-2008 10:57 PM
Exhaust Cross Connections Other Than X or H? JohnTN Engine 2 06-23-2006 06:04 AM
small tubes added to headers for more power?.... sc2dave Engine 10 03-07-2005 06:35 PM
more exhaust questions!! levens Engine 1 04-15-2004 08:35 PM
Exhaust sizing help needed for 454HO with EFI vernw Engine 4 03-29-2002 10:59 AM
