Exhaust sizing question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2009, 04:13 PM
Quick question here. Are catylatic converter and muffler pipes measured in inside or outside diameter? What I mean is the 2 inch long inlet and outlet exhaust pipes attatched to the converter, if it states "2.5 in. inlet outlet" on the muffler or cat listing details is this referring to the I.D. or O.D. of the pipe?? Also is normal exhaust pipe measured in O.D., I think it is but I am double checking. So if a cat is measured in I.D. and exhaust pipe measured in O.D. would this be the proper type clamp to use to attach them? http://store.summitracing.com/partde...5&autoview=sku
Thanks for the help,
keith
Old 03-09-2009, 06:20 PM
one is ID inside diameter the other outside diameter so one slips inside the other u can use that clamp but i 'd just use a standard u clamp or have it welded together... if it says 2.5 in and out then u have to get the next size pipe to fit over those ends like 2 3/4"
Restrictive Exhaust Question Regal Beagle Engine 13 08-26-2008 07:17 AM
Exhaust Size Question: 2-1/2" or 3" leejoy Engine 4 08-14-2008 05:32 PM
Exhaust System Question - Best Method leejoy Engine 12 08-14-2008 12:19 PM
Exhaust question for super/turbo members jameskirk1 Engine 7 08-18-2005 06:58 PM
exhaust cut-outs question bigpapagun Hotrodding Basics 8 01-27-2005 03:01 PM
