Exhaust Welding Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2005, 09:10 PM
A friend of mine told me I can weld stainless exhaust tubing with my mig ,without using stainless wire or changing gasses .Is this true ?
Pro's /cons...???
thanks Dave
Old 08-17-2005, 09:28 PM
rrmccabe's Avatar
GM Muscle
Yes, but then you have rusty joints. The weld and area around it no longer are "stainless"
Rich
Old 08-17-2005, 09:37 PM
That was my first thought(rust)
Do i need to switch gasses if I go with stainless wire or is argon/co2 ok.
Dave
Old 08-17-2005, 09:47 PM
rrmccabe's Avatar
GM Muscle
The welding supply guys will tell you no you cant do it. Or mine always did.
But honestly I have ran out of gas and grabbed the bottle off our "steel mig" and used it for stainless on the MIG and the TIG.
I did not have any problems at all. Was there any? I dunno. I am sure an expert could argue it as my welding salesman always did.
But it looked great and we had no structural problems that I am aware of.
Rich
Old 08-17-2005, 09:50 PM
Thanks Rich.
Dave
Old 08-18-2005, 01:18 AM
I have also used normal steel gas in combination with stainless wire to weld stainless, and it worked. Probably there's a bit more splatter or something only a professional would notice. The joints will be blue afterwarts, but there's an etching paste especially for this. You brush it on, wait an hour or two and rinse it off, then the stainless will look as before welding. The blue colour is only on the surface and this paste contains acid and just removes that thin layer. It should be rust free again after this procedure.
Regards
Martin
TIG Welding Question H2Os50 Garage - Tools 25 02-12-2005 04:58 PM
Chevelle Exhaust Question - 3" too loud? JamesRS Engine 15 06-13-2004 11:50 AM
Pontiac 455 exhaust question leeralidak Engine 2 03-04-2004 12:40 AM
camaro exhaust question. 84_sportcoupe Engine 5 02-07-2004 09:14 PM
Welding exhaust piping 84Z General Rodding Tech 5 01-02-2004 02:39 PM
