exhaust X pipe - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2011, 08:00 PM
deckofficer's Avatar
www.tbuckets.lefora.com/
Last wiki edit: List of hotrodding forums
Last journal entry: Trans swap
Wiki Edits: 12
exhaust X pipe
During my tranny swap I had to fab a new trans support that will interfer with my dual exhausts. I run a stock exhaust manifold with seperate pipes and mufflers for each bank without a H or X pipe. Since exhaust fab is needed at this time, I figure to kill two birds with one stone and finally get an X pipe. My question is, will the X pipe still have the benifits with a manifold instead of headers/collectors?
Bob
http://www.carcraft.com/techarticles.../photo_09.html
Old 01-18-2011, 08:05 PM
matts37chev's Avatar
I don't understand?
Last journal entry: this is only a test
it should still help
Old 01-18-2011, 08:23 PM
Wiki Edits: 12
Matt,
Thanks for the prompt reply, I'm getting to love this forum. I agree with you, but just wasn't sure. I know it will quiet the exhaust by about 8db regardless of manifold vs. headers, but just wasn't sure the peformance increase would be close to the same.
Thanks alot,
Bob
Old 01-18-2011, 08:35 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
yeah i agree it shouldn't be that much noticeable difference if any at all. Can't hurt only help.
Still going to be the same effect on performance should be just fine.JMO
Cole
Old 01-18-2011, 08:45 PM
Wiki Edits: 12
Cole,
So you agree that the percentage of performance increase would be about the same regardless of manifold vs. headers/collector? I know the headers would be better, just don't have te room for them.
Bob
Old 01-18-2011, 08:55 PM
eloc431962's Avatar
Wiki Edits: 37
Originally Posted by deckofficer
Cole,
Bob
Hey Bob I think With headers would be best no doubt in my mind on that, But what i am saying is if you don't have the room for headers and have to run manifolds, Sure there is going to be a difference between the two. But i don't see it being that much of a difference and i wouldn't worry about it.JMO
Are you running center-dump manifolds now ?
Cole
Old 01-18-2011, 09:05 PM
Wiki Edits: 12
yep, ram horns.
Bob
Old 01-18-2011, 09:14 PM
I don't understand?
you better get that wire on the right side by the fuel line tied down, its rubbin on the frame
is your in line rad cap lower than the top tank? how well does that work?
depending on the rad i end up using, i may have to do the same thing
Old 01-18-2011, 09:17 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I could be wrong, but I think percentage wise, the gain would be greater using an "X" w/the less efficient cast iron manifolds compared to headers.
But that doesn't change the fact that the overall difference favors headers over the cast iron manifolds- even w/an "X".
Old 01-18-2011, 09:31 PM
Wiki Edits: 12
Matt,
Wire on my "to do" list. Due to the height of the neck, the cap is at top of tank level, but not above it like it would be on the upper tank.
Bob
Old 01-18-2011, 09:34 PM
Wiki Edits: 12
Cobalt,
A greater gain percentage for my less efficient manifold is a good thing. Thanks
Bob
Old 01-18-2011, 10:03 PM
The rams horns are the est flowing factory manifolds,IIRC they are about on par with shorty headers. The x pipe will really change the sound. Gives it a nice racy sound.
Shane
Old 01-18-2011, 10:35 PM
Wiki Edits: 12
Shane,
I was hoping for a decrease in sound to the tune of about 8 db. This 383 is at least twice as quiet as the hot cammed 355 circle track engine I had before. It isn't too loud now, but since the T was built as a "sleeper", a quieter rumble is preferred. The hood line convinces everyone that the only thing that would fit is a 2.3 L Pinto engine.
Bob
Old 01-19-2011, 09:28 AM
It does decrease the sound somewhat,but gives the sound a more like that of a OHC engine. http://www.youtube.com/watch?v=FBH2N4ovBaM
Shane
Exhaust Pipe jbossler Engine 4 07-23-2010 05:37 PM
???about exhaust pipe on 2.2 s10 Robbie Engine 4 05-08-2009 03:54 AM
exhaust pipe hotrod fozzie Engine 1 06-28-2008 08:23 PM
Exhaust pipe Clearance? Z-Money Pit Engine 5 02-09-2006 09:07 AM
x-pipe, h-pipe and other exhaust questions smlblcks10 Engine 7 11-25-2003 06:05 AM
