I don't see a problem with that.
is it solid
if the bindo is solid, no cracks or rust underneath go fo it ... I would wonder if they didn't sand to top coat what it's like underneath
IF it was ever exposed to moisture without an epoxy primer over it, get rid of it all!
I see so many vehicles driving around with exposed bondo, plain old primer, etc. Don't these people know that bondo and regular primer will absorb moisture and start rusting underneath? |
I have found it more effective to get that old bondo off and fix the metal under there as it is likely that the previous guy covered up a mess..I see this a lot as some one wishes to do something of a temporary nature and winds up creating a bigger mess than if he had done it right in the first place and also spending a great deal more money in the bargain..
Just my take on this one.. Sam
Plastic filler is cheap, do you really want to sand it down, prime, sand some more, paint it then have the filler fall out. I would grind or sand it off, redo it, have peace of mind knowing it was done right.
you could sand it and prime it for now if it is just too ugly to leave until you can do it right, but doing it right means getting rid of it all so you know what is underneath. Then you can straighten the metal and you wont need as much filler to make it right.
| Quality of Bondo | bartamos | Body - Exterior | 16 | 10-24-2006 04:22 PM |
| Removing old bondo | arionrjw | Body - Exterior | 5 | 12-23-2005 12:16 AM |
| Removing old bondo | arionrjw | Body - Exterior | 1 | 12-21-2005 08:48 PM |
| Bondo vs Dynatron | ChrisMiddleron | Body - Exterior | 10 | 08-29-2003 04:07 AM |
| How long does it take thin amounts of bondo to crack? | stonedchihuahua | Body - Exterior | 14 | 07-12-2003 08:02 PM |
