Expansion plug - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2012, 05:48 PM
chief36chevy's Avatar
Last journal entry: Hood holder/horn mount
Expansion plug
Iím working on my 1936 Chevy truckís front axle. I took it apart to sand blast and paint it. The king pins and bushings were fine with no play. My problem is the expansion plugs are buggered up and need replaced. Apparently I was not the first to remove these and replaced them. Anyway getting back to my problem, I measured the hole and the plugs and found them to be 27/32 in.
I have googled them and found that Dorman made them, but I canít find them.
Does anyone know where I can get some expansion plugs without buying a king pin set?
Old 03-30-2012, 07:56 PM
expansion plugs
check your local automotive store.most have an assortment of expansion plugs.i would think the non cup type plugs should work.
Old 03-31-2012, 05:11 PM
Found some
I had checked with NAPA and was told that they had none in their region.
I double checked and found some on rock auto.com.
Expansion plugs? jason777 Engine 4 09-13-2011 09:00 PM
283 Expansion plug locations luckynumberslevin Engine 3 12-16-2010 09:29 PM
Thermal expansion of pistons derbytech Engine 14 05-12-2007 03:26 PM
HR.com site expansion ChevelleSS_LS6 Hotrodders' Lounge 13 04-10-2005 11:58 AM
tail pipe expansion 2.25 to 2.5 spinn Engine 1 10-29-2004 11:58 AM
