Expansion plugs? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2011, 05:02 PM
jason777's Avatar
Last journal entry: Start Up
Expansion plugs?
Hi, Guys.
I know my engine has three 1/2" expansion plugs underneath the rear main cap, but the freeze plug kit came with some smaller plugs as well. Does anybody know where they go?
Thanks.
Old 09-13-2011, 05:45 PM
engineczar's Avatar
The typical freeze plug set comes with two different size small plugs. 3 go in the oil galleys behind the timing chain. One of the other two sizes goes in the oil galley under the rear main cap. Early pre 86' blocks use one size and later blocks use the other. You will end up with an extra plug.
BSE Racing Engines
Old 09-13-2011, 06:42 PM
jason777's Avatar
My block has NPT pipe plugs in the oil galleries. There are still several small expansion plugs in the kit that are not accounted for.
Old 09-13-2011, 08:54 PM
Originally Posted by jason777
Hi, Guys.
Thanks.
Pre 85 blocks used Pioneer # EPC-95 and the same one under the rear cap the later block used EPC-105 which is a smaller plug 3 in back of the timing cover and the same size under the rear cap.
There are also some blocks that take two 16MM plugs in back of the timing cover.
Old 09-13-2011, 09:00 PM
jason777's Avatar
Thanks, Guys.
I only have one 1/2" plug under the main cap. Apparently, they gave me a bunch of different sizes for different generation blocks. I thought "No way there can be that many holes".
I also found a thread below that deals with the plug under the main cap.
plug under #5 main bearing?
Thanks.
283 Expansion plug locations luckynumberslevin Engine 3 12-16-2010 09:29 PM
Radiator Expansion Tank - VENT TUBE Sin7 Engine 12 09-18-2008 08:16 PM
Thermal expansion of pistons derbytech Engine 14 05-12-2007 03:26 PM
HR.com site expansion ChevelleSS_LS6 Hotrodders' Lounge 13 04-10-2005 11:58 AM
tail pipe expansion 2.25 to 2.5 spinn Engine 1 10-29-2004 11:58 AM
