Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Expectable horsepower?
Old 12-01-2012, 05:05 AM
454C10 454C10 is offline
stock hp is 275 with the tiny stock cam.
should make maybe 300 with the bigger cam.
330 with headers and exhaust
Are you going to put on a intake and carb or use the stock efi?
That engine has a factory roller cam so I hope your cam is also a roller cam.
You also need to modify your vortec heads to handle more lift.
I would also recommend doing a little DIY bowl smoothing on those vortec heads, especially around the exhaust ports.
