explain 4L80e yokes - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2008, 10:20 AM
explain 4L80e yokes
Teach me a little about 4l80e Yolks please.
I want to know the part number or where to get another yolk like the one I'm about to cut up here:
http://www.mez.co.uk/dcam/DSCF2121.JPG
I obtained that with a 4l80e and 1996 350 chevy engine from some big delivery van that was scrapped (therefore i never saw the vehicle and wouldn't know what it is anyway)
This is a bolt in yolk that has a recess inside it for an oil seal. It has 32 splines, well actually 31 spines and one missing. The machined part where the oil seal/bush runs is 3.150" long if that helps.
I cut it up and machine down the casting to get it looking like this:
The weld it to another shaft to get this:
Unfortunatley - it didn't weld true, so I need to make another one. (holding it in the lathe this time)
Bigger photos of it and the engine if it helps are ere: http://www.mez.co.uk/4l80e-1.html
I'm also looking at just getting a custom shaft made from scratch, why does the OEM shaft have one spline missing inside? - If making a new one - can I omit it?
Presumably if I had a new solid shaft made, I could also omit the oil seal as the new shaft would be dead-ended.
any assistance appreciated - I'm sure my long suffering 700r4 will be pleased when it can retire from duty.
And finally, I'm aim to eventually put about 600ft/lb's through that welded shaft - i fishtailed the weld - so hope it will hold. The current 700r4 is done the same way, with a welded shaft and has never broke.
Old 01-03-2008, 06:28 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
there are 'yokes'... not yolks
Old 01-03-2008, 08:01 PM
31 five window
Last journal entry: grill and rear end
I am not sure but it looks like it is the same as a TH400. I will try to find out for sure. Are you building a 4 wheel drive vehicle?
Old 01-03-2008, 08:59 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
you will find that most the out put shafts on a 4L80e have threaded holes in them.
A t-400 yoke fits this output shaft. 32 spline count.
A holding fixture of some type and proper welding would provide a fairly straight part.
for what fitment is this shaft?
Old 01-04-2008, 12:37 AM
Its to adapt the 4l80e to the Land Rover LT230 transfer box, which is in a Range Rover Classic - which is converted into a Dakar Kit car.
I intend to leave the shaft in the lathe when i weld it this time.
Any idea why the OEM yoke has 1 spline missing ? - lube?
Googling "yokes" is getting me better results - doh, no wonder!
thanks.
Eliot.
www.mez.co.uk
Practical tq limit of 4L80E curtis73 Transmission - Rearend 17 11-07-2007 03:06 AM
Jet 4l80e Tranny Chip Concern ALASKAN Transmission - Rearend 3 04-11-2006 09:02 PM
4L80E HD Transmission Gene Abbott Transmission - Rearend 0 10-31-2005 09:26 PM
Need some tranny help. 4l80e Bruce Wang Transmission - Rearend 3 09-19-2005 04:19 PM
First 4L80E build questions. bugsdad Transmission - Rearend 12 10-22-2004 08:40 PM
