Explain how to build a very high compression small-block: - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2012, 01:40 PM
Banned User
Explain how to build(/or modify one) a very high-compression small block---like 14:1 if possible. If not possible, then then next highest ratio---like 12, 13:1.
Don't worry about detonation, we'll use water injection for that.
Basically, i am trying to have my cake and eat it too here. And i have to post these questions as they pop into my head or i may forget them later.
The end goal is to have a truck that can tow 6000lbs with no problem---that is to reasonably keep a steady 65mph even on slight hills. AND still get 20+ mpg when unloaded.
Old 08-20-2012, 01:54 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
And this is why we have diesel engines.
Old 08-20-2012, 02:09 PM
x2 use the money you would use to build the engine and swap in a 6bt cummins it will do all you ask for and more reliability to boot
Old 08-20-2012, 02:24 PM
vinniekq2's Avatar
research the new mazda engines, both the diesel and economy 4 cylinder gas use 14:1
Old 08-20-2012, 02:28 PM
Greg T's Avatar
www.krusinklassics.net
You're going about it all wrong. Compression and towing should never be used in the same paragraph. Heavy towing should have a max SCR of about 9.0:1. Stroke it, give it good heads, use a grunt cam and enough rear gear. But NOT compression.
Old 08-20-2012, 03:10 PM
go on 4btswaps.com there is tons of info on there on diesels if you would like to go that route believe me it is one of those things once you get a diesel under the hood you'll never go back. there is a 04-05 chevy 1500 with a 4bd1t that my buddy owns that no bs hand calculated is getting mid 20's city and low 30 high way which i doubt youll ever see out of a full size truck with a gas engine. i had a full size 95 chevy dually with a 12 valve cummins that we swapped in and it would get me solid 18 mpg mixed driving and that truck always had my welder compressor tools 24/7 now i got a ford with a 7.3 that i will swapping a cummins into when i get some extra cash flow honestly i love them with the right tuning and understanding of gearing thay are real good alternative not only that i run 100 bio diesel for years which make my cost per mile similar to a 4cyl compact truck running gas off the pump
Old 08-20-2012, 03:14 PM
E85 will be your friend. Why the hard-on for 14:1 CR? Just cuz?
peace
Hog
Old 08-20-2012, 04:30 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Diesels are in the 17:1 compression range.
If bent on a gas engine, I would consider a sbc 400. Those are sbc torque monsters if you're going to be towing.
Old 08-20-2012, 05:49 PM
vinniekq2's Avatar
s10 racer, look up mazdas new 14:1 diesel
Old 08-20-2012, 06:51 PM
S10 Racer's Avatar
I guess I should have been more specific. The Duramax diesels are running around 17:1 compression. The diesels need high compression for combustion. I remember back in the 80's when Olds converted their gas engines to diesels, they were turds.
Old 08-21-2012, 02:42 PM
The terrible thing about GM's Oldsmobile gas to diesel conversion being a turd was that GM did that kind of conversion from gas to diesel before with the making of the GMC Toro-Flow V6 diesel from the gas truck V6 of about 10 years earlier. Problem for problem these two engines walked the same path as if GM learned nothing from the Toro-Flow experience.
Bogie
help me build a strong high reving small block 400 mopar dman16 Engine 15 05-29-2010 08:55 AM
help me build a strong high reving small block 400 mopar dman16 Engine 53 08-27-2009 11:06 PM
400 small block compression 19nova72 Engine 2 07-20-2005 02:29 PM
high revving small block mitmaks Engine 19 07-30-2003 03:15 PM
Compression on a 400 small block LiLEcZ40 Hotrodders' Lounge 1 06-09-2002 02:32 PM
