explain this suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2007, 03:27 PM
cboy's Avatar
Last journal entry: Finished
Has anyone seen this truck in person or in a mag and can you explain the front suspension? These are the best pics I could find (from wackydave's great collection of car show pictures). I'm guessing it uses some sort of torsion concept. Great rod BTW.
Always learning...and sharing what I've learned.
Old 02-05-2007, 03:32 PM
Wiki Edits: 31
I'd bet that there is a torsion bar setup, that connects to those 2 posts coming out the side ( 1 for each side ), so the bar's will twist, and support the weight.
Old 02-05-2007, 03:51 PM
cboy's Avatar
Would the torsion bar eliminate both the spring and the shock? I don't see either.
Also, I want to make sure I attribute those pictures properly. They come from Dave Lindsay's web site SoCalCarCulture.Com and were taken by him. Some great car pictures there BTW...and tons of them.
Old 02-05-2007, 10:58 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
These are always hard to figure out unless you see the build pics. This looks like a Lil John Buttera build. Take a look at the build pics for his lakes modified roadster in Street Rodder magazine web site.
http://www.streetrodderweb.com/featu...akes_modified/
This rod could use similar principles in the build but obviously very different. In the mag pics it looks like the coil over shocks are connected to the four bar/torsion bars on the inside of the frame. There have been several torsion bar/beam axle front suspensions built on high dollar rods recently because they seem to get a big reaction because every one wants to know where the springs and shocks are. Most mags don't seem to be too interested in the various choices of front and rear suspensions possible and usually just give a one sentence remark about the type of suspension. They seldom give a good pic of what it looks like or how it was done. The web pics in this case do it quite well but it would have nice to have a description/caption of what is being done. As for the pics you posted unless someone has build pics we can only guess how it was done.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 02-06-2007, 07:21 AM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
Thanks alot home brew, now my head really hurts. There's a lot going on in Lil Johns roadster, the pictures don't do it justice. I still can't figure out how he did the front end. It looks like the coil overs serve the rear through a series of cantilevered links, but I can't see much for the front. It does look like a pivot shaft in front of the motor connected to teh upper bars with links extending backward, but can't see what they're connected to.
Keep searching cboy, that model a truck is really cool.
Old 02-06-2007, 08:00 AM
It looks to me like a suicide style front end where the spring is tucked up under the radiator support and the eyelets connect to the bottom inside on the hairpins . Very oldschool , very well done . swaZZie
Old 02-06-2007, 08:14 AM
cboy's Avatar
I was hoping one of our left coast members had seen this rod in person and could fill us in on the detail. Swazzie might be right that there is a leaf spring tucked up under there, but the mounting eye and shackle is certainly well hidden if that is the case.
Old 02-06-2007, 08:36 AM
Those lever arms sticking out from under the front frame corners are indicative of a torsion bar setup. Haven't seen any more detailed pictures of this vehicle to be able to give you a better idea.
I've seen cars built in the 40s with torsion bars. One in particular was the Willingham Roadster, a 26-27 T Roadster with a Deuce shell, three piece hood with hinged top and inside latching mechanism, full belly pan, oddly single exhaust which drops out of the belly pan near the engine crosses under the pan and re-enters the pan to a muffler mounted crossways in the truck and exiting through the back panel, 39 Taillamps, shortened windshield with curved top glass, 59A engine with converted Lincoln distributor, triple carns, Lincoln Zephyr OD transmission, K-H bent-spoke 16" wheels with Ascots on the rear. This car was built by a Lt. in the USAAF soemtime shortly after WWII, he signed the back of the dash panel. Current whereabouts unknown, was in Houston TX through the 70s-80s then moved to CA???
Old 02-06-2007, 11:03 AM
aka Duke of URL
I wonder...
If the torsion rods are at the pivot point of the radius rods and what appears to me to be some type of sway bar (easily discernable on the right side-bent bar forward-maybe left bar rearward) acting as both shock and sway bar?
It's is definitely beyond this Redneck's understanding...
Old 02-06-2007, 11:26 AM
woodz428's Avatar
Troll Hunter
Originally Posted by KULTULZ
I wonder...
I may be misinterpreting your observation Gary, but I think the "bent" arm you are referring to is actually the steering link. As for the suspension, it could be a bunch of different types. Instead of torsion bars at the radius rod pivots they could be connected to a set of coil overs that are under the car. It isn't a really clear picture, but I think that there is a cross leaf on the front as has already been suggested,tucked away for a very clean look.
Old 02-06-2007, 01:52 PM
I think on that little truck that bent rod you see is the panhard bar. Just under it to the right is another rod which I believe is the drag link.
The pivot point of the radius rods is not where those torsion bar arms hook up but rather at the rear of the radius rods where they meet the frame. Notice the radius rods are filled from end to end with a plate to strengthen them for their new role as a suspension member. I imagine that the bottom bar of the radius rods has some flavor of pivot like a spring perch with a shackle or link to the torsion bar arm.
Just guessing from these pictures which don't show much of what wer'e talking about. The shocks could well be lever arm style mounted inside the front crossmember actuated by another arm on the torsion bars.
Old 02-06-2007, 01:56 PM
poncho62's Avatar
Wiki Edits: 5
Maybe, it has NO suspension........I dont see license plates either....or brake hoses
Old 02-06-2007, 02:49 PM
Last journal entry: More on the Cobra Engine
I'm almost positive it uses torsion bars up front, and the whole front end is pivoted from there. If you were to jack the car up, the front would fold down from the torsion bar location.
Also there is a hydraulic brake fitting on the passenger side front that looks like it goes to the back side of the front axle, t'ees there and feeds both sides hidden behind the axle.
The rear is a bit more hidden, and could be any number of different type of suspension. It is very clean and well...it sure has our interest.
Old 02-06-2007, 04:15 PM
Arrowhead's Avatar
Wiki Edits: 5
Could be something like this pretty slick setup on this model A - torsion bars run back to air bags.
As others have said, if you look real close behind the axle of the pickup in question, it looks like there are some links that may connect to a torsion bar inside the frame.
ID:	18277   Click image for larger version
ID:	18278   Click image for larger version
Old 02-06-2007, 08:28 PM
cboy's Avatar
Here are a couple more shots...but I don't think they reveal much. 454Rattler just emailed and said that car was in the March issue of Street Rodder...but apparently no info on the suspension.
Help...rear suspension design questions FrankR Suspension - Brakes - Steering 1 06-02-2006 07:50 PM
Hotrodders Knowledge Base: Suspension - Brakes - Steering Jon Suspension - Brakes - Steering 0 11-26-2005 06:29 PM
Rack & Pinion Steering on a Chevy C-20 Suspension? Dusty82 Suspension - Brakes - Steering 3 03-01-2005 09:15 AM
how to hang a C- 4 suspension ? Redmist Suspension - Brakes - Steering 1 12-31-2004 11:48 AM
Mustang ii Suspension 41fordcoupe Suspension - Brakes - Steering 14 06-11-2003 08:12 PM
