Seen it many times, more so on bonded linings than riveted, but it happens to both. It happens on disc pads too. Usually it's from rust between the lining and backing. Sometimes fluid contamination eats away at them.
I guess not really seen many times, but more than a few. I used to work where I did a whole lot of brake inspections. |
Didn't happen to use cheapo offshore parts on your last brake job, did you?
Ontario Rodders |
Just the fact that the shoes were 34 yrs. old would have made me want to replace them when you put it all together. I imagine if they were bonded shoes, which I am sure they were, The bonding adheshive got brittle through the yrs. and let go and the shoes grenaded.
Yes they were bonded and best guess the original factory shoes. I used them because they looked really good and the rear end project was eating my wallet up alive. The first rear end was a big block Mustang unit and was too wide, the next was mid 50's truck housing and axles, the spring pads need to be relocated 180*, so I did that, the Good posi (track lock) unit from the Mustang rear wound up needing to be rebuilt $$$, then the truck axles needed to be machined for a passenger car bolt pattern and the brake drum locater stub also required machining, that cost $100 and on installation I discovered that I had two left axles "S#*T". and on and on it went.
I know what you mean, I have done things similar to that myself trying to save a buck or two. It will usually come back and kick my butt Though, LOL.
I was working on my brother in laws 1970 240z,tune up ,brakes,etc.He brought me the parts,which where the cheapest he could get.I came to stop and thought someone rear ended me,like your wife said loud bang.Just like yours the shoe came apart.
I always try to get the riveted shoes if they are available. |
When I built my wifes 65 Triumph chopper a few years ago we bought it as a project bike and it had sat since 1975. We got two Invader 5 spoke steel wheels still in unopened boxes. I took the front wheel out and it was the tiny front brake type wheel. I pulled the backing plate out to look at the shoes and the linings fell off the shoes!! What a trip..
| Brake shoes to big for the drum? | 72 chevy elcamino | Suspension - Brakes - Steering | 17 | 06-04-2005 08:26 PM |
| Wheel clunking and brake squeal | skizot | Suspension - Brakes - Steering | 29 | 10-09-2004 06:17 AM |
| 1950 Dodge Truck brake shoes | CrashFarmer2 | Suspension - Brakes - Steering | 4 | 01-07-2004 04:43 PM |
| brake shoes | fred56 | Suspension - Brakes - Steering | 2 | 09-04-2003 07:07 AM |
| Hotrodders Knowledge Cluster: Disc Brake Conversions | Jon | Suspension - Brakes - Steering | 0 | 08-29-2003 03:34 PM |
