Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Explorer Rear- Use clip or go with a 4 Link?
Old 10-29-2012, 08:58 PM
cucumber1949 cucumber1949 is offline
T-Bucket, Corvette, Mustang
Originally Posted by timothale View Post
why not just keep the 2 rear spring layout, buy some brackets from speedway for the rear springs, . add a sway bar and shocks with a length you need.
If the vehicle you have is a unibody, I'm not quite sure how you would do the clip as the Explorer is a frame vehicle, so you would be grafting the frame to the unibody. I agree with timothale - if your vehicle can handle the rather long leaf springs that come with the Explorer rear axle then use those with a shorter shock. Beyond that the 4-link is a good option.
