Explorer Rear- Use clip or go with a 4 Link? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2012, 06:58 PM
I thought I would just do a rear clip so I could keep all the Explorer parts- shocks, sway bar, ect.
Well the shocks will be 7 inches into the trunk and using the explorer frame would kill off most of the trunk as it has a ladder frame.
My buddy wants just drop in a 4 Link- we can do that but I know Ford put much thought into making a 'System" for a vehicle with weight and height- I plan to keep the car high.
My car is 4000 Lbs and a unibody- A Russian ZIM
Thoughts on the Explorer - OR suggest another vehicle - OR the 4 Link....
ID:	68695   Click image for larger version
Name:	ZIM and Explorer frame.jpg
Old 10-29-2012, 08:48 PM
Wiki Edits: 27
leaf ?
why not just keep the 2 rear spring layout, buy some brackets from speedway for the rear springs, . add a sway bar and shocks with a length you need.
Old 10-29-2012, 08:58 PM
T-Bucket, Corvette, Mustang
If the vehicle you have is a unibody, I'm not quite sure how you would do the clip as the Explorer is a frame vehicle, so you would be grafting the frame to the unibody. I agree with timothale - if your vehicle can handle the rather long leaf springs that come with the Explorer rear axle then use those with a shorter shock. Beyond that the 4-link is a good option.
96 Explorer rear springs in F1? crownver Suspension - Brakes - Steering 3 03-17-2011 07:58 PM
8.8 rear Mustang / Explorer 35prog Transmission - Rearend 1 11-05-2009 06:39 PM
rear four link vs. triagulated rear link kit b.c.kid Suspension - Brakes - Steering 15 11-29-2004 01:48 AM
4 link vs. triangulated 4 link. rear suspension bentwings Suspension - Brakes - Steering 4 11-23-2002 12:44 PM
Parallel 4 link or Triangulated 4 link rear ? RonWood Suspension - Brakes - Steering 1 11-13-2002 07:25 AM
