Exposed Adhesion Promoter
I noticed in the DuPont tech manual on "blending" that they recommend
adhesion promoter put down first and extended out past the final blend area. I thought this odd, does the adhesion promoter that's left exposed just buff away? I've never tried that. Anyone here do it that way?
That's not the question.
They clearly show the adhesion promoter extending out PAST where the FINAL (last) coat of clear ends. So there's still some adhesion promoter on the panel with nothing over it AFTER the job is done. http://pc.dupont.com/dpc/en/US/html/...ClearBlend.pdf |
I agree, but that's not the question.
Believe me, I know how to blend, I've been blending for over 30 yrs. I'm still looking for an answer to why "THEY" (DuPont) would recommend leaving adhesion promoter uncovered. Do you buff it away after you're done ? (Why is that question so hard to understand)
Yeah, for sure the adpro buffs right off because it is so thin, but there there must remain an edge of it that will be exposed right by the clear. Obviously Dupont feels adhesion is the main concern, and maybe their adpro is UV stable, hard to say.
P.S. I have done a similar procedure in jambs, with Bulldog though, where an area around the latch gets fixed and spotted in. It works good in jambs... |
In part 4 of application they explain to mix adhesion promoter with your mix as you read. However, the last sentence tells you to reduce further and finish off your blend. Meaning go ahead and cover that area previously uncovered. It can get confusing the way they write their instructions.
Their method is not the best in the long run as in the future it maybe buffed by someone who doesn't know about the blend. Used car dealers use that method to repair their vehicles. It looks good going down the road till later. |
I don't like that either, thanks
| Adhesion promoter | oldred | Body - Exterior | 4 | 10-13-2007 07:23 PM |
| Does bulldog adhesion promoter need a primer? | SplitFire | Body - Exterior | 7 | 01-14-2006 02:43 PM |
| Bulldog adhesion promoter. | jcclark | Body - Exterior | 8 | 08-25-2005 06:29 PM |
| dupont waterborne adhesion promoter | 327amc | Body - Exterior | 0 | 01-04-2004 05:18 PM |
