Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Express van side doors pop interior panels off when closed?
Old 11-26-2011, 06:42 AM
chucksrt chucksrt is offline
These panels have hooks on the lower half (looks like an upside down L) and it latches into a bunch of holes in the door (square holes), and on the top there are plastic nubs that stick out of the panel that connect to metal clips around the window glass moulding. I mentioned the hinges because there is a very slight amount of movement if you push on the door (against the hinge). It seems that when the door is closed that it may be hitting the step at the bottom of the door and popping the panel off. But the doors look to be true?
