Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 02-15-2005, 02:24 PM
camaro80 camaro80 is offline
Ext. and int. balanced rotating assemblies
Hei!
Can I use int. balanced rotating assembly in block where used to be ext. balanced assembly.
Is it possible to use stock 1-pc rear main seal on older(pre-'87?) sbc block?
Is there any performance difference between int. and ext. balanced assemblies? Which should I prefer?
Block is 350(383) sbc.
Thank you!
Old 02-15-2005, 02:52 PM
johnsongrass1's Avatar
johnsongrass1 johnsongrass1 is online now
Race it, Don't rice it!
re: Ext. and int. balanced rotating assemblies
The blocks don't make any difference at all. To get a two peice to work with a one piece you'll need an adaptor available form speeday motors and the like.
Old 02-15-2005, 02:55 PM
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
But a one piece rear crank won't fit an early two piece block. As for internal vs external balance= No real difference unless you are making over 750 horse and turning 8000 plus rpm.
Old 02-15-2005, 02:56 PM
machine shop tom's Avatar
machine shop tom machine shop tom is offline
ASE-Certified Master Machinist
Yes.
No.
Internal.
tom
Ya cain't fix stoopid, but ya kin TAX it!
Old 02-15-2005, 03:04 PM
So I have to go with 2-pc crank in old style block and internal is better? Correct?
Old 02-15-2005, 03:27 PM
Yep and Yep.
tom
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
