Exterior ideas for firebird - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
  #61 (permalink)
Old 10-24-2010, 07:40 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Originally Posted by bigdog7373
isnt that kinda dangerous? should i just get shorter springs?
Its only dangerous if you try to cut them on the car.
I've cut a set on my pickup, but of course I removed them first.
You could buy new springs, but my suggestion is in reference to the inexpensive way of lowering.
  #62 (permalink)
Old 10-24-2010, 09:21 AM
Of course the rear is leaf so you would need to run lowing blocks or something.
  #63 (permalink)
Old 10-24-2010, 09:46 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Drop spindles or lowering springs.
Cole
  #64 (permalink)
Old 10-24-2010, 10:26 AM
Onefunponcho's Avatar
well said!
to me it is.
Well put That's what really matters
  #65 (permalink)
Old 10-24-2010, 12:20 PM
eloc431962's Avatar
Wiki Edits: 37
It's a gonna be a sweet ride.
Cole
  #66 (permalink)
Old 10-24-2010, 12:51 PM
bigdog7373's Avatar
Of course it's fast
does anyone know what the stock spring length is?
  #67 (permalink)
Old 10-24-2010, 01:28 PM
Last journal entry: Paint
Just lob off 1 coil. It's no big deal. Use what you have to work with.
  #68 (permalink)
Old 10-24-2010, 01:42 PM
bigdog7373's Avatar
Of course it's fast
The thing is that the stock springs are really soft and i don't want the larger tires to rub if i hit a bump or turn hard. I also hate how the car feels when you turn, it leans and feels really sloppy. I want it to ride like a BMW, low, smooth, good handling, and sort of a stiff ride quality.
  #69 (permalink)
Old 10-24-2010, 01:53 PM
Put some WS6 springs in it. Put a bigger sway bar in it.
  #70 (permalink)
Old 10-24-2010, 02:03 PM
bigdog7373's Avatar
Of course it's fast
ok, after looking at prices for springs i don't think i can afford springs, lowering blocks, and rims all at one time. I'm just gonna try cutting the springs and putting lowering blocks in the rear. Now much do you think i should lower it? I don't know if i should go quite as low as that sick looking black car cuz i don't want problems with speed bumps.
  #71 (permalink)
Old 10-24-2010, 02:25 PM
eloc431962's Avatar
Wiki Edits: 37
Get your tire and wheel combo first and then see how much it can be lowered. JMO And you can cut the springs or heat them but if you cut them do alittle at a time so you don't go to much all at once. But eventually you will or should get the proper springs. Again JMO. either way it's going to change the camber on the front end.
Cole
  #72 (permalink)
Old 10-24-2010, 02:30 PM
bigdog7373's Avatar
Of course it's fast
I kinda want to stick with the 15x7 wheel size cuz i have fairly new tires and i'd hate to have to buy rims and tires for full price. I was thinking that i could find some stock rims and tires off newer car that would look good. I thought the corvette wheels would look cool but they prob won't fit.
  #73 (permalink)
Old 10-24-2010, 02:32 PM
Most of those aftermarket wheels go out of style quick. I wouldn't build a car around a set of wheels. Used aftermarket wheels are everywhere. If you have to have them let someone else take the hit on them.
  #74 (permalink)
Old 10-24-2010, 02:35 PM
eloc431962's Avatar
Wiki Edits: 37
This is true, And i don't build around the wheels and tires but you do need to know or have a idea of what you are going to run before you go cutting springs and things to get it lowered. JMO
Cole
  #75 (permalink)
Old 10-24-2010, 02:40 PM
I have a bunch of cut coils. 1 coil is nothing. He can cut 1 coil out no problem. Some springs you can cut out 2 coils.
