Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - External Cooler Or Not?
Old 04-22-2013, 05:18 PM
engine24355 engine24355 is offline
[QUOTE=NEW INTERIORS;1669342]If you have one inside the rad. You shouldn't need one..I never run one inside the rad, Don't need any thing adding heat to the water,, Just my way of thinking,, I always run one like this under the car where it can get a good air flow...
I was thinking the exact setup you posted here. If I run an external cooler I would like to tuck it under on the frame to a keep clean look and away from hot exhaust temps under the hood. I had a cooler on my last project (23 T-Bucket) that was mounted under the body. Looks like you have a C-Cab...very cool! Thanks!!
