Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - External Cooler Or Not?
Old 04-22-2013, 04:24 PM
NEW INTERIORS NEW INTERIORS is offline
life is a temporary assignment
[quote=engine24355;1669353]
Originally Posted by NEW INTERIORS View Post
If you have one inside the rad. You shouldn't need one..I never run one inside the rad, Don't need any thing adding heat to the water,, Just my way of thinking,, I always run one like this under the car where it can get a good air flow...
I was thinking the exact setup you posted here. If I run an external cooler I would like to tuck it under on the frame to a keep clean look and away from hot exhaust temps under the hood. I had a cooler on my last project (23 T-Bucket) that was mounted under the body. Looks like you have a C-Cab...very cool! Thanks!!
I like to use the one that has two fittings on one end,, You can use less hose and keep it a cleaner look,,
Yes I have a C-cab build... You can see the whole build here..Building A Homemade C-cab !!!
