External Cooler Or Not? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2013, 03:45 PM
I know this has been discussed numerous times, but wanted to ask for some current thoughts on running an external trans cooler or not. I know this is a must for towing vehicles etc, but for my application I am really questioning rather it is necessary. That said, I am running a pretty stock chevy small block with a T350 tranny in a 50 Ford. Currently, there is an external cooler in front of the radiator. Do you guys think this is necessary in a stock application? I really would like to eliminate as it is not installed properly in the first place, but if it is needed I need to correct the installation etc. Or replace with a better cooler setup.
Thanks!!
Old 04-22-2013, 03:51 PM
life is a temporary assignment
If you have one inside the rad. You shouldn't need one..I never run one inside the rad, Don't need any thing adding heat to the water,, Just my way of thinking,, I always run one like this under the car where it can get a good air flow...
Old 04-22-2013, 04:18 PM
[QUOTE=NEW INTERIORS;1669342]If you have one inside the rad. You shouldn't need one..I never run one inside the rad, Don't need any thing adding heat to the water,, Just my way of thinking,, I always run one like this under the car where it can get a good air flow...
I was thinking the exact setup you posted here. If I run an external cooler I would like to tuck it under on the frame to a keep clean look and away from hot exhaust temps under the hood. I had a cooler on my last project (23 T-Bucket) that was mounted under the body. Looks like you have a C-Cab...very cool! Thanks!!
Old 04-22-2013, 04:24 PM
[quote=engine24355;1669353]
I like to use the one that has two fittings on one end,, You can use less hose and keep it a cleaner look,,
Yes I have a C-cab build... You can see the whole build here..Building A Homemade C-cab !!!
Old 04-23-2013, 01:32 PM
I was following your build on the tbucketeers forum, but lost track of it as i am not on the foumn very much any more since selling my bucket. I also caught your build on Gearz. You have some awesome fab skills my friend. Anyway, thanks again for your help.
By the way, where do you usually mount your cooler along the frame?
Old 04-23-2013, 02:37 PM
malc's Avatar
Living At The Speed Of Life
The rad water adds heat to the transmission to get it up to working temp quicker, the trans fluid is not cooled by the engine rad.
Old 04-23-2013, 05:36 PM
To be 100% correct,, It does both..
Must not hurt to not have it heat up.. Never burnt one up..
I'll leave all mine like I been doing it for years..
Old 04-23-2013, 05:39 PM
Thanks for the kind words,, Yes I seen it on Gearz last night again,, Still funny to watch..
I mount it off the frame, Sometimes off the bottom of the car,, Depends where I have a good clear shot with no heat around close..
Glade to help out..
Old 04-23-2013, 11:16 PM
malc's Avatar
You got me there
Old 04-24-2013, 03:31 AM
blackmagic67's Avatar
internal trans. coolers can cause you some trouble .i have seen some leak coolant into the tranny. not agood thing. better to go to external cooler.
The Following User Says Thank You to blackmagic67 For This Useful Post:
NEW INTERIORS (04-24-2013)
Old 04-24-2013, 08:41 AM
You got me there
No problem Malc.... Just wanted to add the rest....
People have gotten away from running them inside the rad,, I seen where the lines inside rot or break, then your trans is sucking water into it... Not very good,, Plus by the time you realize it,, It's way to late..
One way to fix it and not have to worry is to put it under the car like everyone is now doing,,, Seen many even last without a cooler,, I wouldn't do it that way,,
But seen where people take a peice of tubing and run it from one fitting make a few turns and run it right back to the other one and run for years that way...
I wouldn't..
Old 04-24-2013, 10:29 AM
malc's Avatar
You missed my irony.
I run my trans with an external cooler, the trans fluid does not run through my rad, no provision for it to do so.
It takes forever for the trans fluid to warm up let alone get hot.
I can run my Camaro for an hour to the coast at 90mph and the trans is still not hot enough to burn off contaminants in the fluid.
Even in traffic it does not heat up, keeping it out of overdrive for a while does get some heat in there.I´ve also got a thermostat to control the trans fluid, it fully opens at 180º.
The manufacturer runs the fluid through the rad to get the fluid hot, that burns off accumulating muck in the fluid.
Think about an engine running at 240º, do you think the water in that rad is cooling the trans fluid ?
An external radiator is usually added for towing to bring the temperatures back to some kind of equilibrium.
Old 04-27-2013, 10:46 AM
I have one of those large single pass coolers I bought at a swap meet and haven't gotten it put on yet. But can someone tell me what the difference there is between the singe pass and the double pass coolers. Mine is the large single pass cooler. Mine is the long two foot single pass and I though about disconnecting my rad and using this only.
Old 05-05-2013, 10:56 PM
Last journal entry: Old guy's low cost Chev coup.
Been running the same TH350 in my 51 (Chev) coupe now for over 20 years. First year after I built it, had trans cooler made into bottom radiator tank. One of the cooling lines leaked and lost all my fluid and killed my trans before I knew it. The first indication was smoke (fluid blowing out directly on muffler) and trans slipping, but was too far from anywhere to fix it. Had it towed home ($) and rebuild trans ($). I did the loop-back on the cooler line fittings. about foot and half or 2 ft of tubing after all the bends/fittings where made. Have driven it coast-to-coast (Cal. to Fla.) and half way back (live in Texas now) with no further trouble with the transmission. Its still running strong. Was thinking couple years ago to get some line and reconnect the cooler, but never got around to it and don't think after all these years it needs it. The TH350, I think worst thing you can do to it is give it a connectors/fittings/hoses that leak. Loss of fluid will kill it in a heartbeat.
using a trans cooler for a gas cooler? biohazard_81c10 Hotrodding Basics 2 09-05-2011 02:09 PM
External Trans Cooler, Radiator Cooler, or both? 2004R & 383 SBC Cousin_Joe Transmission - Rearend 1 02-27-2008 09:10 AM
external trans cooler for 700r? mattson70 Transmission - Rearend 2 06-29-2007 04:40 AM
Can I use a trans cooler only without a radiator cooler? supercab78 Transmission - Rearend 5 04-14-2005 01:46 PM
Internal vs External dollybud Electrical 4 08-05-2002 06:48 PM
