Originally Posted by Frisco
Automatic transmissions work best when the operating temps are around 180 degrees.
Having the trans fluid too cold can be as bad as having it get too hot.
I agree completely, but if you're wondering about it getting hot enough, take a morning drive around the block and then lay your hand on the TC. Just that 1/2 mile jaunt will get things quite warm in there, so getting it up to temp doesn't seem to be an issue.
I run a large, 4-pass, 1/2" tube cooler with a dedicated 10" electric fan that gets triggered by an adjustable thermostat on my tow rig. I have it kick on when the tranny temps hit around 220. It doesn't go through the radiator. It only comes on every once in a while when not towing, but it will cycle on and off when I have 10k behind it. That tells me its getting up to temp during daily driving, but its still adequately cooling at max effort.
