External fuel pump for gm tbi - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 12-17-2012, 06:35 PM
I'm looking for a suitable in line fuel pump for a gm tbi system. I know most people say to keep the stock system cause it's most reliable but that won't work for me since I am swapping this system into a tractor. stock tbi system run around 11 to 13 psi I've heard so I'm looking for a pump that runs around 20 psi. many people suggest the e2000 but I'm skeptical about using it since its rated at 70 to 95 psi. Any suggestions for what I should use?
Old 12-18-2012, 11:37 AM
Carter P50001 is the commonly-used external pump for TBI conversions. Holley also sells a similar pump with about 15 PSI output.
Old 12-18-2012, 01:53 PM
Napa makes a really good in-line electric fuel pump.....the part # is E8012S. It is the "ONLY" external pump that I use now & I havent had any problems w/ it. Good Luck!!
Old 12-20-2012, 07:58 AM
I ended up using a carter GP4601HP. maximum 18 psi. will let you guys know how it works
Recent Modern Electronic Engines posts with photos
quiet down noisy external electric fuel pump CraigsClassics Electrical 41 06-23-2016 06:30 PM
Internal or External fuel pump: advantages? Vetteman61 General Rodding Tech 6 03-28-2012 03:37 PM
external electric fuel pump sbc 350 vapor lock problem Syn77 Hotrodding Basics 8 10-16-2011 08:46 AM
External Fuel Pump kb9vzl Engine 3 04-10-2007 06:36 PM
Best external fuel pump for a TBI 350? nat Engine 3 03-30-2007 12:28 PM
