external to internal voltage regulator - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2005, 11:14 AM
TASHAN's Avatar
Last journal entry: Vortec L31/880 383 project (16)
I have a 70 chevelle malibu that is equipt with an external voltage regulator and I have an alt. on a new engine I put in that has internal voltage regulation. How do I change the wiring from external? Or would it be better to get another alt?
Old 09-04-2005, 08:18 PM
docvette's Avatar
Wiki Edits: 12
Regulator
Doc here,
Is that a 1 or 3 wire Alternator?
A 1 wire is simple, just run the 10 gauge red to a proper fuse link and connect at the starter solenoid main cable bolt..and your good to go..
If it's a 3 wire...STOCK <--read) wiring is as follows...
Ignore the second red...It's used in 81 models only...
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 09-04-2005, 10:13 PM
TASHAN's Avatar
excellent! thanx dood!
Charging system info............... poncho62 Electrical 11 11-26-2005 08:53 PM
External Voltage Regulator Wiring dsmith1279 Electrical 1 12-17-2004 09:33 AM
Electrical Short, Possible Voltage Regulator Claude Electrical 2 06-21-2003 01:13 AM
Internal vs External Balance 614streets Engine 3 05-28-2003 01:25 PM
57 Chevy generator to altenator swap Rodrunner Electrical 2 07-17-2002 09:59 PM
