External Trans Cooler, Radiator Cooler, or both? 2004R & 383 SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2008, 08:12 AM
I'm putting a freshly rebuilt 2004R behind a chevy 383. This setup is in a 1970 Impala. I was looking at buying a new aluminum radiator, for a little better cooling, and because the original one I have has been dripping from the fins.
What woudl be the best setup for cooling the auto trans? I see that I could buy an aluminum radiator that will fit in fine, with a trans cooler inside, or I could buy an add on trans cooler. Is one better than the other? Would it be a good idea to run both in series of each other?
Thanks, Joe!
Old 02-27-2008, 09:10 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi Joe,
Heat is the biggest reason for transmission failure.
Plum the return line (from the rad to trans) with a
cooler, that way the fluid is brought down from about 225* to about 190* then further cooled buy the cooler, this imo is the best way to set them up.
Also, when it's severely cold you can reverse this & use the rad to keep the trans fluid warm, or cover it, as you can over cool as well, (trans fluid to thick).
Take care,
Rich
Internal... External... Balance that 383!! KSailer77 Engine 8 06-09-2007 08:22 AM
383 external balance question ljjjrome Engine 24 01-18-2007 08:31 PM
383 sbc questions brandon624 Engine 3 09-20-2006 07:31 PM
come ONE come ALL! SBC debate: 327, 350, 383 or 400. which do you like best and why? tony350ss Engine 50 06-14-2006 09:14 AM
SBC Oil Cooler Adapter Delirious2000 Engine 1 02-19-2006 10:21 PM
