External Voltage Regulator Wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-12-2004, 02:03 PM
Just wanted to quickly confirm the wiring on my external voltage GM regualtor.
On the wiring harness there is an F, 2, 3, 4
The F is to the 12V Constant terminal
The 2 and 3 wire are to the altenator
The 4 wire is to the run side of the ignition switch
Old 12-17-2004, 10:33 AM
Your "F" terminal goes to the alternator (that is the field)
#2 goes to the alternator as well, that termanal is the R terminal on the alternator
#3 is the battery connection and usually has a fusable link in it. this will run to your battery, horn relay, amp gauge, and the "BAT" terminal of the alternator
#4 is the ignition switch
I checked this with with my wiring diagrams as I was writing this, hope this helps
