extra friction plate in 4l60e rebuild. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2009, 07:16 PM
I began my transmission rebuild and everything is going alright....
My question im not sure about is (if anybody has a manual or know how) is about the forward frictions around the forward clutch sprag assembly.
I removed the snapring and thought i missed a part that came out.
I removed exactly what the manual i have shows and it is:
Removed: ----------------- Reinstalled:
Snap ring ----------------- Snap ring
Thick tapered spacer ------ Thick tapared spacer
friction ---------------- friction
steel ---------------- steel
steel ------------- ^"FRICTION
thick bottom spacer ---------------- Steel
--------------- Thick bottom spacer
the ^"FRICTION is the extra one i added in the stack and the snapring lined up perfect and didnt take any forcing in. Anybody know if the extra friction is bad?
Old 03-16-2009, 07:24 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The clutch packs have specifications for how much space is required to be between the retainer and first element of the pack. Go by that tolerance to determine if there's room for anything extra.
Just because it fits, means little. There needs to be room for the pack to expand w/heat as well as for fluid.
Old 03-16-2009, 07:42 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
stoggy,
what you installed is incorrect
you may notice one of the bottom steels was a waved plate for a cushion effect when the clutch pack applies.
there must be a minimum of .050 clearance on this clutch pack.
Old 03-16-2009, 07:51 PM
I wish my computer manual let me copy pictures out of it for descriptions.
I installed what was removed except for the extra friction. The forward clutch waved plate did not come out of the part i disassembled just the manuals labeled thick apply plate, a regular steel instead of waved plate (there was none), the proper steels/frictions, and selective backing plate.
Like i mentioned above everything went together as it came apart except the extra friction. everything still spins freely with clearance but i will double check clearances to be sure.
Old 03-16-2009, 07:55 PM
incase it helps the info i am using is on page 75 of M. Miller manual. Auto 211
Link to download
http://members.torquecentral.com/joel/4l60e/4l60.zip
Mine is a 1994 if that makes any difference
Thanks for the replys
Old 03-16-2009, 07:58 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
There are kits for the 4L60E that have thinner friction/steels- is that what you're using, perhaps?
There's not much difference in the appearance between the two types.
Old 03-16-2009, 08:30 PM
i looked at the info and it just said setup for 6 3/4 clutches....
I will check the free play tomorrow while its still easy to get at.
If i find anything ill update
Thanks again for the info
Old 03-16-2009, 09:22 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
It said "set up for six", and that's what you've installed. So this IS a "thin" kit, and you will probably be good to go once you verify your clearance. Good deal!
Old 03-16-2009, 09:33 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
seems to me the topic was the forward frictions at the forward sprag - 5 or 6 frictions, now the subject is about the 3-4 clutch pack.
My previous comment was about the forward clutch pack. 6 frictions in the forward pack is incorrect and i suspect incorrect setup. good luck with it...
Old 03-17-2009, 06:28 AM
Yes and it still is about the forward clutch pack, i was including the only info about the clutch count that came with my rebuild kit.
I will be measuring clearances and double checking, thanks again for the info
Old 03-17-2009, 08:09 PM
Ok so here is the final verdict. I took a good good look and it turns out i mistook the wave plate for a flat one so i was missing the waved plate instead of having an extra friction.
Thanks for the help everyone
Old 03-17-2009, 08:25 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
So had Crosley's advice been heeded from the beginning, all this would have been unnecessary.
Good call, Croz...
Old 03-17-2009, 08:58 PM
Im not sure what you mean by that. What i did was already done and i was asking questions to lead me in the right direction. I took everyones reply into consideration and it led me to the solution.
If i didnt take heed to the advice from the beginning of course i would still be running around in circles without my problem fixed.
So again thank you for all your NECESSARY replies that led to my solution!
I appreciate it
Old 03-17-2009, 09:15 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I mean exactly what I typed- had Crosley's advice been heeded from the get-go, this thread wouldn't have been necessary.
It's a nod to Crosley's having called it right, the first time.
Whether or not you were able to make use of his thoughts on the matter, is your issue.
It's about him, not you.
Old 03-17-2009, 09:42 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
we need to keep in sight the idea of providing assistance to folks here.
Since I work in the transmission industry I try to provide correct info , brain farts do happen at times ..
and sometimes I misunderstand a posted question or 3
T-400 clutch plate rebuild Scooby333 Transmission - Rearend 4 01-10-2009 09:53 PM
GM disc/disc master cylinder kleen56 Suspension - Brakes - Steering 11 10-16-2008 11:11 PM
4L60E rebuild kit ????'s Turbonoma Transmission - Rearend 0 04-14-2007 12:10 PM
8BA flathead oil pan cleanout plate powerrodsmike Engine 0 09-13-2005 04:52 AM
T-350 rebuild question Marcus Transmission - Rearend 3 07-01-2004 07:48 PM
