extra heater core? or what is it. stock '51 Chevy
Replaced the coolant hoses on my '51 Chevy when I got home from work. 1 of the heater hoses runs into the passanger side fresh air box, has 2 fittings, 1 in and 1 out. There also very hard to get to, especially with the road tube right next to the inlet side... anyone know what it does? I have a '37-'53 Motors manual but it does not cover it..The hoses are replaced and it's fine but, I'm just curious. coolant that came out of that section was a bit nasty. I'm going to flush it out
I also have a 51 chevy and I believe they go into the heater box under the dash. One from the water pump and one into the passenger airbox, right?
Each time I start on a new project, I purchase the original factory service manual for it, either an original or a reprint. You would be well-advised to do the same.
http://www.faxonautoliterature.com/1...nt-P10135.aspx I've used Faxon as a source for these for decades. |
Here, here, I have learned this much too late in life. I wouldn't live without a manual for my cars now. I am blown away with how much I get out of them. I have done this stuff for a living for 35 years and I "thought" I knew better than to need one of these manuals, I was dead wrong. Brian |
The original manual is on the old car manual project. I checked there, but it doesent refrence it.. It's good for other things, but it's bookmarked. My 1953 edition Motors manual covers 90% of what I need.
I did buy a reprint owners manual.. I still have an orig Rambler TSM I got from Faxxon http://chevy.oldcarmanualproject.com...shop/index.htm |
first off....
First off, I'm sure you two are the only ones who have thought to consult a factory manual, because who in their right mind would ever think to look there. You guys are the only ones to know this valuable piece of information.........really???? Give me a break. if you want to suggest something, do it without the "My god, it's soooo obvious". Well advise yourself to some mannners.
Matt167 is right, I also have the manual (in print and bookmarked online) and it doesn't reference this part. AT ALL. However, after closer inspection on my own 51 once I got home from work, it appears there is a valve on the inside of the firewall. Mine is attached to a cable that also increases the heat. It appears that the heater core is in the passenger side air vent and and,at least in my car, that when you call for temperature it lets more hot "water"(yes, I know it's not actually water) through the core and opens the ventilation system more. See pictures for more detail. Hope it helps. |
Death to spammers
I didn't think to suggest when I first responded to your post what it could be as your car is one I have no experience with and didn't have a clue as to what it was you were describing. But along with Low-n-slows photos and a little google search it sounds like that is what you are looking at, the "Heater control valve" which are sometimes located in the system somewhere and not on the engine it's self like all the heater control valves on every car I own. If it has heater hoses inside the passenger compartment, that is one ignorant design that is for sure. But one you live with, put new quality hoses there with new clamps and you will never have a problem again as far as you own it. I would think about replacing valve too, but only with a quality NOS (New Old Stock) like I used in my Rambler don't replace it just to replace it using some Chinese junk from today. Replace it if it looks at all funky, with a quality valve. If you replace it with some Chinese junk, it might as well be left the way it is. Brian |
And by the way on your question of another heater core, this isn't an unrealistic question, many cars over the years have had more than one heater core. First off, there are modern mini vans and SUV's that have heater cores in the back (along with an AC evaporator). But I know that I worked on a Lincoln Continental from the forties (as I remember that is what it was) that had a round heater core under each front seat! So you had personalized heat controls for the driver and passenger!
I had forgotten about that car until I did a little google search for your question and found a Lincoln with two heater cores in the dash, one for passenger and one for driver. ![]() Brian |
The heater hoses both terminate at the firewall, just 1 hose has 2 connections in the fresh air box on the pass side. The box itself is bigger than the driver side box which is pretty much a 5-6" tube tube, and the pass side has access panels. I'll have to pull them off and see whats inside. Heat works as it should, and I have replaced all the hoses with Gates high quality. hoses. complex job for hoses, as the radiator has to come out to make it easy, and the powerglide cooler has to get loosened to get the intermediate hose changed on it. heater hoses were the easy part.. The HCV works and it opens and closes when the temp control is slid up and down
| Heater core | kruzr | General Rodding Tech | 0 | 05-22-2008 07:55 PM |
| heater core ? | runn141 | Engine | 17 | 11-27-2006 05:29 AM |
| Will heater core (and others) fit? | BMM | General Rodding Tech | 5 | 11-25-2006 11:03 PM |
| heater core | Brian Morency | Engine | 6 | 08-27-2004 12:55 PM |
| Ever install a heater core in a chevy Van? | tm454 | Hotrodders' Lounge | 6 | 04-04-2004 01:31 PM |
