extra insulation help.. - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
  #61 (permalink)
Old 01-23-2009, 04:14 PM
Thanks to you & Dan for the advice. I'm a master at the "ah, sh*#" approach to mechanical work & developing a similar expertise for electrical work.
  #62 (permalink)
Old 01-25-2009, 10:19 AM
I was phone
Lots of info in this thread. Some good some bad.
I will start by saying this:
This topic has been discussed at length for more than 5 years on various car audio boards, and many of the same conclusions have been drawn, but as a results of the topic having such a lengthy life, much of the misinformation has been sorted out.
The people on the car audio forums that were using the Peel and seal product form home depot or Lowes found that stuff melts, and doesn't last more than 2 years in most cases. Sometimes it does though. It really depends on the temperature.
The asphalt mats look very similar to real vibration damping, but they are nothing even close.
Many people use them to save money, which is understood, but there are some significant drawbacks to using a roofing product in a car.
1. Asphalt is toxic a gives off gasses when it heats up.
2. Asphalt melts at 180 degrees 100% of the time. There is no getting around this fact. If it lasts longer than one season, consider yourself lucky.
3. Asphalt is not elastomeric, so it will not convert vibrations in to heat ( a necessary part of energy conversion for constraint layer viscoelastic dampers (CLVED) to work)
4.The foil is too thin. Aluminum foil on a CLVED has to be at least 3 mils to constraint the elastomeric layer enought to reduce vibrations.
5. They do not weigh enough. The asphalt mats only weight about .3 lbs per sq foot. This would not be too bad if they were true CLVED, but they are not. so, the only way the asphalt mat are able to help with vibration reduction is by adding weight to the panel. This is not very efficient or effective when the product weighs so little.
The problem is that they mats look very similar to real CLVD mats and so there are a number of companies that sell them to customers that do not know the difference. Many of the companies that have been suggested in this very thread are guilty of this betrayal.
After all, the product has black adhesive with silver foil. Why would anyone think any differently?!
I am not going to point out any names of my shady competitors in this thread, but I will tell you guys an industry secret. This industry secret is 100% accurate 100% of the time.
There is not a sound deadening manufacturer in the entire indutry that puts a constraint layer damper on a roll right off the extruder. Not one.
If it comes on a roll, it was originally designed by the manufacture to go on a roof. Companies that sell foil backed vibration dampers on rolls (even butyl ones) by them from roofing mastic manufacturers and then sell them to the public as vibration dampers.
Without exception!
Companies that make CLVED mats which are designed to go in automobiles have much higher standards to live up to than those that produce roofing products. The product they (we) produce come in sheet form only.
1. The foil needs to be flat and non-creased in order to work at 100%
2. the foil is too thick to roll up - Look at the Dynamat extreme door kit. This is a kit that is rolled up AFTER it comes off the line. IF you get your hands on one you will see how difficult it is for them to roll up and put in the box.
3. Dampers in sheet form are easier to get applied by OEM companies.
4. CLVED are designed at the specific viscosity that is required to reduce the most amount of automotive vibrations, while rolled, roofing products are set to the exact viscosity to work on a roof. On a roof, there is very little need to a specific viscosity, which is why there is so much variance between batches or asphalt materials. Some batches of asphalt work decent, while other fail right off the line (when used in cars). The QC for asphalt mats is nothing even close to the QC for CLVED.
There are lots of reasons why using a roofing product in a car is a bad idea, and lots of reasons why true vibration dampers will outperform them every time.
If anyone has any sound deadening questions, I am always happy to help, whether you use Second Skin or not.
ANT
  #63 (permalink)
Old 01-25-2009, 11:11 AM
ANT,
a "friendly" suggestion...
"let sleeping dogs lie!!!!"
your product was a top rated in the "shoot out" and speaks for itself!!!!
if you want to post competitor negatives then back it up with independent scientific testing results...
(or you can end up in court)
I would like to read the MSDS sheet on your product and any ASTM testing results if you can post a link..
  #64 (permalink)
Old 01-25-2009, 11:33 AM
I was phone
Originally Posted by red65mustang
ANT,
True, we did fair well in the Sound deadener showdown, but my post has very little to do with our product. It has more to do with informing the board about the differences in marketing hype and warning guys about possible problems they might have with products that are not specifically designed for the application at hand.
What might you hope to see with our MSDS?
What do in case you accidentally ingest our product?
ASTM rating? Sure.. we have them.
We don't publish them though. In comparison to other companies that inflate and exaggerate their ASTM results, ours look pathetic. We are left to either lie and inflate our numbers or look incompetent in the shadow of lies that other companies chose to publish in lieu of accurate numbers.
We choose not to publish our numbers because of these exact exaggerations.
ANT
PS.
I am not too concerned with "ending up in court" as I have not mentioned any competitors by name and have not said anything that is not absolutely true. It is the shady companies that are selling toxic asphalt as vibration dampers that should be worried about ending up in court..
  #65 (permalink)
Old 01-25-2009, 03:09 PM
ANT,
the law says simply and clearly:
"The public has a right to MSDS data upon request."
I am requesting a copy of the Dampifier and Damplifier Pro MSDS sheets.
  #66 (permalink)
Old 01-25-2009, 03:20 PM
I was phone
Which law is that?
1. according to OSHA we not required to give MSDS sheet to consumers at all, but can do so at our own free will. MSDS sheets are for people that work with the products on a daily basis.
2. The products youare requesting an MSDS sheet for are Non Harzardous articals which, according to OSHA do not require an MSDS sheet. The only reason we have an MSDS sheet is for our suppliers that require them from their vendors dispite OSHA regulations
Here is some reading for you:
http://www.ilpi.com/msdS/faq/partb.html#downstream
The purpose of an MSDS sheet to to inform people that are working with hazardous chemicals on a regular basis to the dangers & precautions of that chemical as well as the action required if exposed in a dangerous way.
Sending you an MSDS sheet seems to be nothing more than egaging in a pissing match which I am not interested in joining.
If you want an MSDS sheet, you will need to send a formal request through a legit channel. Today is Sunday, and I am at home, not in a possition to provide you with one, and really not all that interested either.
Your request can be made to:
service@secondskinaudio.com
ANT
Headliner insulation oldred Interior 4 07-15-2007 02:37 PM
Garage Insulation Question........... djjc76 Garage - Tools 22 12-17-2006 03:44 PM
Insulation in shop Timido Garage - Tools 15 12-15-2006 03:04 PM
insulation for heat and noise? Pharmy Interior 3 07-30-2003 10:39 PM
Headliner, etc insulation Wmarden Interior 2 12-04-2002 07:23 PM
