Extra Long Sanding Boards ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2005, 07:41 PM
AngliaBob's Avatar
It just takes time and money
Last journal entry: Specifications
All,
I have "Googled" for hours, and been to numerous sites, with no results.
I am trying to find a long board sander, either 36" or 48".
I have a 16 and a 17, but I would like something longer.
Any help is appreciated,
Bob
Old 05-11-2005, 07:48 PM
Adjustable flex sanders!
Ive got em and love em
Give that a google if not try
www.autobodystore.com
or the home site
www.adjustflexsand.com
Old 05-11-2005, 07:53 PM
Wiki Edits: 49
It's very easy to make your own. Just use a piece of 3/4" plywood and add on a couple handles then just use stick on sanding paper. Works pretty well and you can make any length you want.
Old 05-11-2005, 08:02 PM
I make my own out of 1/8" alluminum sheet and add an oak handle, cover the alluminum with a couple layers of duct tape and apply self adhesive sandpaper from a roll, they work great. I haven't found a need for any longer than 32". Just make sure they are truly straight or you'll have troubles.Bob
Sanding, Dry vs Wet, Air vs Elec Bluepen Body - Exterior 3 05-12-2003 03:45 PM
flexable sanding blocks Maverick Body - Exterior 7 04-10-2003 11:58 AM
T-350 Long vs short shaft change zachscc Transmission - Rearend 2 01-21-2003 01:53 PM
How Long? WOW! Madd Syntst Hotrodders' Lounge 20 08-16-2002 09:13 AM
How long has the project been tore down? Kevin45 Hotrodders' Lounge 6 07-25-2002 10:12 AM
