Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Extra-tall Jack Stands?
Old 02-22-2013, 05:15 PM
sedanbob's Avatar
sedanbob sedanbob is offline
To maintain stability, with increased height you should also increase the size of the base. Using a standard base but making it taller, it will be less stable. One easy way might be to weld on a larger flat plate under the legs.
