Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Extra wire on a Alternator
Old 11-15-2012, 02:11 PM
JeffB's Avatar
JeffB JeffB is offline
Tuff-Stuff has a chart here: http://www.tuffstuffperformance.com/...structions.pdf Note it is "minimum requirement"! I used 6 gauge with my 105 AMP,the cables that Ford uses from solenoid to starter are usually 4-6 gauge and have flat terminal ends for EZ hookup to the Positive battery terminal and alternator post you can get those at most parts stores $6-$8.In some cases you may need a longer battery cable bolt.Because of the length in your case I would go 4 gauge.
