Extra wire on a Alternator
Hi,
I'm starting to wire my 37 Dodge. I have a Kwik wire kit. I will be using a 105 amp alternator and the Kwick wire instructions say I need to run a second wire 4 gauge wire from the alt. to the starter. Is the 4 gauge a little over kill? Could I use a 10 gauge wire? New cars use 10 gauge for their high amp alternators. Any help would be appreciated Sam |
You can go straight from the alternator to the battery instead of going to the starter where the positive cable from the battery attaches. Are they telling you to use both (talking about the "second wire" reference)? For that matter you could use a remote solenoid and get rid of the positive battery cable to the starter that's always hot. More here. |
Tuff-Stuff has a chart here: http://www.tuffstuffperformance.com/...structions.pdf Note it is "minimum requirement"! I used 6 gauge with my 105 AMP,the cables that Ford uses from solenoid to starter are usually 4-6 gauge and have flat terminal ends for EZ hookup to the Positive battery terminal and alternator post you can get those at most parts stores $6-$8.In some cases you may need a longer battery cable bolt.Because of the length in your case I would go 4 gauge.
You can use some variety in gauge size depending on the type of wire used. There's a huge difference in amp rating between different styles of wire, and coarse strand #4 wont hold the same amperage as fine strand #4 like welding cable.
Much of the cheap battery cables, and jumper cables made in recent years use less strands, and they wont hold as much amperage. If you go to an electrical supply house, and get #4 welding cable it holds more amperage, but will be much more flexible, so it will work better to connect your alternator. I've got mine done in welding cable, and also my remote cable from the battery in my trunk to the starter. The amp rating for #4 welding cable is double what coarse strand #4 like THW, or THHN are, so you can also go one size smaller with welding cable and get a higher amperage rating. |
Thanks for all the replies. I went down to my local welding supply and purchased a 6 gauge cable. I was able to get small ends so they would fit the stater.
I did call Auto Zone to see if they sold 8 gauge wire. Their parts pro told me the smallest wire they sold was 4 gauge:rolleyes: |
I get my 8 gauge from NAPA.
Welding cable is not rated for automotive use, the insulation does not have the same oil and gas resistance of SAE spec. auto wiring. Napa wiring meets all specs.
| All times are GMT -6. The time now is 12:52 PM. |
