extracting engine codes - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2008, 12:09 PM
Hey guys
This isn't a hot rod question but I'm sure someone will know the answer.
I'm trying to check the codes on my moms 94 buick regal. I think its a 3.8L.
On the older gm's you can just jump a wire from the a and b pins and get the engine light to flash. In this car there's only pins in slots A,M,D, and J. Can I jump any of these pins to extract the codes or do I need a special reader.
Its the same size ALDL I've seen in the older gm's. I didn't think they started OBDII until 96 but maybe this was a transition year?
Thanks for the help
Old 04-08-2008, 08:09 AM
66chevystepside's Avatar
I would suggest going to an auto parts store that does free diagnostics and get the codes that way - they usually even give you a printout. Some 1995's have the newer ODBII diagnostics but '94 should still be ODBI.
CA smog questions...engine swaps curtis73 Engine 25 11-28-2012 08:11 PM
GM 5.7L crate engine suffix codes SCRUBBY Engine 2 11-30-2009 04:36 PM
Block Engine Codes HELP???? Twin Camaro's Introduce Yourself 4 03-28-2008 08:37 PM
Whats the correct temperature my 350 should be running at? batman09 Engine 101 10-23-2005 12:29 PM
My 305=C8L...can't find it on chev engine codes list frankthetank Engine 0 10-27-2003 09:09 PM
