extreme budget t bucket - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2006, 02:06 PM
Hey everyone, I'm trying to get some more ideas on another project that I have been tossing around in my head. In the vain of original hot rodders running t buckets on "newer" model a chassis I would like to build a t bucket using a stock frame off of a newer car. I figure if I can buy a running and driving car or truck cheap why can't I strip it down and add a t bucket body on it. The current idea for a chassis is a 94 thunderbird. Being a subframe car it is easy to change the wheelbase, and a high point is that it uses a short arm long arm front suspension instead of struts, and has irs. One downfall that quickly comes to mind is the unusual bolt pattern (5 x 100mm) but I have access to a bridgeport so thats only a minor problem.
The other 2 ideas I had was for a turbo coupe thunderbird or a ranger. But there is the major problem of getting the suspension to ride ok without all that weight on it. Also I thought about the framerails being to wide for the chassis but I don't think thats really a problem because I can weld in rails inside of the other ones then cut the originals off. I'm sure there's alot I'm missing here, so I figure it would be a good idea to run it by others before I dive right in. Any suggestions or thoughts are greatly appreciated.
- Larry
Old 09-22-2006, 02:37 PM
Welcome to Hotrodders.com
We are one of the most diverse bunch of rodders on the net. I myself build a little more traditional style vehicles ... but I am sure someone here will speak up about your project under consideration ...
Deuce ...
Old 09-22-2006, 02:40 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Not a good idea. The T-bird is a Sub frame car...no frame rails so thats no good. If you do use a car that has frame rails... the frame will be way too wide for a T-bucket body. Also the front suspension on the modern frames and subframes looks like crap without fenders. T-bucket frames are cheap and easy to make with 2x3 tubing . You had a good idea...but in reality it just won't work good.
Old 09-22-2006, 02:48 PM
Wiki Edits: 31
unless a body was built around the frame. I plan to do that myself, with an S10 frame out of fiberglass, in a year or so.
Old 09-22-2006, 05:08 PM
Tbucit's Avatar
Last journal entry: Kinda showing off
Why?
First off any one can do whatever they want, but why do any thing like this at all. The t bucket is a simple project. As stated 2x3 or my choice 11/2 x3 is easy to get and simple to weld. ANY OEM frame out in the open on a T would be so ugly you would want hide your head in my opinion.
ID:	15103   Click image for larger version
Old 09-22-2006, 05:30 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Welcome to the site rust_is_free. rust_is_free until you try to get rid of it! The T bucket is a very narrow body and will not adapt to newer frames. What you are thinking will cost you more money and time than building a set of rails from 2X4 tubing ($200 should about cover it). Buy your donor car and keep the drivetrain and part out the rest. Then buy yourself a dropped front axle with brakes and suspension; a steering box and drag link and you have what you would have if you used a donor car/truck. It will look clean and ride well. It will be easy to build and the time you save will be well worth it. This has been talked about many times on this site. Use the search function and type in donor frame or hot rod donor frame or rat rod donor frame.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 09-22-2006, 08:38 PM
home brew's Avatar
Arrowhead - a pic is worth a thousand words. Never did save any pics that looked so gross. Glad you did! Should have those on hand every time someone brings this up again. THANK YOU!!! By the way I followed your build in your journal - great job!!!!!!!!
Old 09-23-2006, 07:20 AM
cboy's Avatar
Last journal entry: Finished
Arrowhead,
Like Home Brew said, that is a GREAT collection of chassis pics...thanks for hanging on to those. My guess is they will be referred to quite often in the future.
Always learning...and sharing what I've learned.
Old 09-23-2006, 08:19 AM
Lost in the 60's
Wiki Edits: 4
Originally Posted by cboy
Arrowhead,
AMEN!
Old 09-23-2006, 09:32 AM
Nightfire's Avatar
Young & Idealistic
Last journal entry: 1950 Fargo - losing hope
Wiki Edits: 4
If you have the skills to adapt a 94 T-bird subframe to run a t-bucket body on top, then you definitely have the skills to build your own frame, axel, radius rods etc. Send me your email and I'll shoot you some plans on how to go about all of that.
How to build a frame
How to build a frame jig
Cheap-o Build
All the tech info for t-buckets
Mike
Old 09-23-2006, 10:31 AM
thanks
I just want to go ahead and thank everyone for their thoughts and feedback. First thanks mike for the links, some useful info there. I have done some frame work before, setting up a four link, front clip, frame rails, etc. but was just looking for an easy way out without having a solid axle. I thought that it would have been too ugly and after looking at the pics supplied by arrowhead, it really wouldn't look too good, with all of the suspension out in the open. matt167's idea of covering up the frame with the body is another idea I had, just make the buckets body a little bit bigger. my main reason for trying to use a stock frame is due to very limited space, the garage is a small one car that i just started renting, so i thought i would try to build something that would fit in it, and i have extremely limited funds, too many projects, and im in college.
does anyone remember a car they called the "spaghetti bender" in street rodder a few years ago. it was a ferrari drivetrain and chassis sitting under a track t body, obviously far more complicated than what i had in mind. i'll try to find it and put a pic up. the body did a great job of covering up the front suspension. my idea was basically to build something that could handle with newer muscle cars and but look better in my opinion. I really am just leary about solid front axles, having no experience with them. Just trying to find something that would be fixable with off the shelf parts. Now im just ramblin. but i guess i will have to reconsider the project and maybe just go back to finishing up my barracuda. Thanks again.
- Larry
Old 09-23-2006, 10:39 AM
Lost in the 60's
Wiki Edits: 4
You can get off the shelf parts and components for solid axles....go to www.speedwaymotors.com A T-frame is a lot smaller that what you were talking about. It will fit in your garage a lot better.
Old 09-23-2006, 03:19 PM
Wiki Edits: 31
add this T bucket off ebay to that list of ugly framed T's. this 1 could have looked decent if curvature was added, but it looks like it was made out of a sheet of plywood. http://cgi.ebay.com/ebaymotors/Other...QQcmdZViewItem
Old 09-23-2006, 04:33 PM
i know that you can get new parts for solid axles from places like speedway motors. what i had in mind when i said that was more along the lines of a regular parts store, like napa. actually i don't know if napa does carry stuff for solid axles, i suppose they may for newer trucks with solid axles. i did see someone use a solid axle out of an f150. anyone know what years had solid front axles? but that may be too wide too.
i do see what everyone means of how ugly a t bucket looks with an exposed ifs. i was just more concerned with how much abuse they can take. coming from a younger generation i have really no experience with solid axles. i just don't want to be afraid of driving the car hard.
- Larry
Need Help!! What Is The Best Bucket Seat For A 55 Chevy tiresmoke55 Interior 36 01-19-2012 07:37 AM
T Bucket Steering and Radius rods plans ken47 Suspension - Brakes - Steering 11 02-01-2007 05:39 PM
bucket t question Bill H Hotrodding Basics 4 08-06-2006 07:21 PM
T bucket front Suspension? bigknowell Suspension - Brakes - Steering 10 07-13-2006 07:00 AM
T Bucket Wiring Harness Tightrodder Electrical 3 02-04-2006 09:22 AM
