Extrernally mounting a gauge on hood - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2013, 05:25 PM
What is the besy way to mount a gauge on the hood? Are they sealed for weather, what to look out for?
I was looking at sandwiching the C mount with 2 soft rubber cards on the rear of the hood vents by the windshield. A couple of screw and nut through the vent slot to secure it as a base. Then use a normal gauge cup with a installed mechanical gauge , like vacuum, boost, etc.
How have others done this. Looking for ideas.
Mounting
Illumination
What rattle can paint for cups cause rustoleum fusion flaked off?
Old 02-13-2013, 05:50 PM
gearheadslife's Avatar
MentalMuffinMan
Mounting
Illumination
the autometer procomp water(liquid filled) will be fine out on the hood as they are sealed 100%)
paint, engine paint.. after painting put in oven at 300* for 30 minutes..
when wife isn't home.. lol
prep and a bake will make a ton of difference
illumination, I use l.e.d's less likely to fail
The Following User Says Thank You to gearheadslife For This Useful Post:
spinn (02-14-2013)
Old 02-14-2013, 03:03 PM
Yeah, LEDs. That would be easy.
Looking at the clamp base, and it might distort the hood vents.
Would double faced hurricane tape work to mount the base? I figure we use it on mouldings and trim.
Old 02-14-2013, 03:07 PM
MentalMuffinMan
get some truck cap foam tape and put that between the cup and hood and bottom bracket and hood..
trim as needed..
replacing factory in dash oil gauge with aftermarket gauge Torque454 General Rodding Tech 3 09-06-2010 01:34 PM
mounting scoop on c/f hood sam_bo3 Body - Exterior 1 12-04-2009 12:17 PM
mounting fuel pressure gauge binder47 Engine 2 03-22-2009 08:16 AM
Quick ? about mounting hood scoop barnym17 Body - Exterior 2 01-27-2009 06:16 AM
Mounting a hood on a 36 ford Dano_37 Body - Exterior 4 02-12-2006 02:15 AM
