EZ Wire kit into 68 roadrunner - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2003, 08:49 PM
Hey guy I am looking to rewire my car. I was wondering if the Ez wire kit would be a good choice or should I get the $600 kit from the paddock.
Old 07-13-2003, 09:15 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
Thumbs up Horvath sez.....
that the ezwire kit is ok......
Old 07-13-2003, 09:25 PM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
EZ-Wire, bro'! It's only $165 and just as good as all the others!
Check out my photo-diary via my site-link below my sig ... if you have any questions, I'm happy to help.
Alan
54 Chevy Pickup
Old 07-14-2003, 05:32 AM
EBlack36's Avatar
Rebuilt Excitment
The only way I would ever go with the kit from the Paddock is if I wanted to keep the car totally correct.
Old 07-15-2003, 08:32 PM
Appreciate the responses. EZ wire it is!!
Old 07-15-2003, 11:20 PM
ChrisMiddleron's Avatar
Hey guys im just woundering when you buy the ez wire kit does it come with the connectors for the specific vehicle. In 2 more weeks im about to buy a new wiring harness on my ride and im just woundering if everything will just plug in. Thanks, Chris
Old 07-16-2003, 02:18 AM
horvath's Avatar
It comes with connectors for the headlight switch, connectors for the steering column and new plugs for the headlights ... everything else gets wired : buy a ton of plastic connectors (blue and red) from Home depot, and two tons of plastic wire ties ... and don't forget lots of split loom -- 1/2" ... 1/4" ...
Plan every single thing (wire & connection) out BEFORE you begin.
Alan
54 Chevy Pickup
Old 07-17-2003, 08:48 PM
New Member
The EZ Wire kit doesn't have connectors for specific vehicles. It is a generic kit with a GM steering column connector as well as the other connectors that Horvath mentioned. It is a very good kit, especially if you are wiring from scratch. Having the wire labeled by heat stamping every 5 inches makes installation easy. (Spoken like a true bench racer. I've purchased the kit, but haven't installed it yet, <grin>.) I bought the kit with the colored wires.
Old 07-17-2003, 09:17 PM
Thanks guys EZ wire it is!
