Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Electrical
  #1
Old 03-23-2003, 03:39 AM
horvath's Avatar
horvath horvath is offline
Acoustic Rock ... for real.
Post EZ-Wire : Reading Wires From Steering Column
I'm trying to determine the hookups for my EZ-Wire kit TURN SIGNAL connections.
The plug on my steering column measures 3 7/8" so I know which connector in the kit I'll be using ... but the colors of the wires on my trucks column are all whacky - it's a 75 Cadillac tilt/tele steering column and I need to run the wires from the EZ-Wire kit for :
L-front Signal (lt blue)
L-rear Signal (yellow)
R-front Signal (blue)
R-rear Signal (green)
Horn (black)
Hazzard (dk brown)
Turn Flasher (purple)
Brake Switch (white)
My question is - how do I best determine which wires in my Caddy column will match/connect to each of the above?
Do I disconnect one at a time and see what happens? Or is there a better way?
Thanks.
Alan Horvath
<a href="http://AlanHorvath.com/" target="_blank">http://AlanHorvath.com/</a>
Old 03-23-2003, 04:17 AM
zonk's Avatar
zonk zonk is offline
Home Built Rods No Rules
Post re: EZ-Wire : Reading Wires From Steering Column
on the connector on the column I believe there should be some letters wiring diagram I have
E -from brake light switch
F - right rear turn/brake
G - left rear turn/brake
H - from turn signal flasher
J -from hazard flasher
K - right front turn
L - left front turn
M - horn button
hope maybe this helps
Old 03-23-2003, 04:56 AM
horvath's Avatar
Ah-haaa!! LOL!
THANKS, Zonk! You did it for me, bro'. I didn't see those letters there before - EZ-Wire gives a list of code letters, but I just missed seeing them in the truck because of all the dirt and crud, darkness under the dash, and them letters being on the underside of the connector.
Man what a nightmare 49 years of unattended wires becomes on an old truck! It sure is gonna feel good when I do this rewiring job!
Alan
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
