Ez Wiring Harness Fan Circuit Problem...help Please - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-28-2011, 04:40 PM
evh1963's Avatar
WOLFE BOTTOM CUSTOMS
Fan
From What I Can Tell Its A 18v 2.5amp That Heavy
Is It Black With Silver Stripe
  #17 (permalink)
Old 10-28-2011, 04:41 PM
evh1963's Avatar
Fan
If It Is Same As I Looked Up It Will Work Fine
  #18 (permalink)
Old 10-28-2011, 04:43 PM
chevyrestore's Avatar
Yeah thick black with silver stripe, looks pretty beefy...what can I do to keep from overheating if this diode fails?
  #19 (permalink)
Old 10-28-2011, 04:45 PM
evh1963's Avatar
Fan
Ok Can U Call Me This Is Tricky To Explain Or I Can Call U But If Not I Will Try To Walk U Throught It 304 248 7659
  #20 (permalink)
Old 10-28-2011, 04:47 PM
sorry at the shop right now, not supposed to be on the phone
  #21 (permalink)
Old 10-28-2011, 04:49 PM
evh1963's Avatar
Fan
Is This Drag Car And Yours
  #22 (permalink)
its a 59 chevy truck, mine and I like to drive it a lot so I want to make sure its not going to fail on me on the side of the road
  #23 (permalink)
Old 10-28-2011, 04:51 PM
evh1963's Avatar
Fan
You Need Spst Switch And Red Led Light Do You Have Them
  #24 (permalink)
Old 10-28-2011, 05:00 PM
no LED but I have a toggle and SPST and SPDT relays
  #25 (permalink)
evh1963's Avatar
Fan
Run Led In Cab Pos Side Of Led To Pos Side Of Fan After Doide Before Fan And Ground To Ground When Fan Is On Led Will Be On Install Switch As A Back Up If Diode Fails And Light Goes Out You Can Flip Switch In Cab And Turn On Fan Direct Or Run Through Relay To Break Harness And Power Direct So Two Ways To Have Back Up Your Choice Relay Has To Be A Dual Hope You Get This All
  #26 (permalink)
Old 10-28-2011, 05:02 PM
evh1963's Avatar
Fan
I Would Get Led
  #27 (permalink)
Old 10-28-2011, 05:04 PM
If I just dont use a diode all together would a relay act as a break in the system when the engine is shut off? I think I have some 70amp relays that would be much stronger than these diodes
  #28 (permalink)
evh1963's Avatar
Fan
Do U Use High Beams Alot If Not Wire It To High Beam Light In Dash As Temp Idea
  #29 (permalink)
Old 10-28-2011, 05:07 PM
evh1963's Avatar
Fan
Relays R Always Better Thats Way All Cars Have Switched To Them And They R Easy To Find Diodes R Getting Harder To Find And Not Made As Well As Years Ago
  #30 (permalink)
Old 10-28-2011, 05:08 PM
so how would the relay be wired to act as the diode would?
wiring harness JSR Electrical 1 07-16-2007 05:09 PM
Wiring Indicator Light into Circuit JohnTN Electrical 4 11-02-2006 07:53 PM
changing engine wiring harness, ran into a lil problem ikeaguirre14 Electrical 9 06-02-2005 06:01 PM
wiring harness rookieracer Electrical 1 11-02-2003 07:07 PM
Hot Rod Wiring Harness HotRodS10 Electrical 3 06-25-2002 12:19 PM
