Pull the glass out and have different sideglass cut that is
taller than the original. I had to do this on my 59----made the glass 1" deeper and then the streetrod power windows would work. Yours being a pickup door----you could even go a bit deeper and still have the glass drop all the way into the door |
Tried a longer piece of glass. Same result. the angle of the lift causes the glass to be about an inch outside the frame at the top of the run. If I disconnect it from the lift, I can make a straight run up into the channel. Back to the same question, can the lift be bent or curved?
power window
35 terraplane |
power window
Looks to me as if you are going to have to move the power window lift, if you can move the glass up and down, and it works, there isn't enough give to take up the amount of glass that is sticking out. you say you have no room at the lift, I would guess you mean in and out. Would you have more room if you moved it down towards the bottom of the door then I think it would have to move to the outside, you would have to get a longer glass but to me, it is not going up at the right angle. IF you can't move the motor you will have to get another unit. Do you have the other side in?
35terraplane |
It looks to me like you can move the lower part of the unit towards the outside of the door and it should fix the problem. You would have to make some sort of spacer for the bottom mount of the unit.
good luck OLDROD |
The lift has a worm type gear inside. The motor is already about as far as I can get it towards the outside of the door, hence why i'm wondering about putting just a slight bend in the shaft of the lift.
window kit
35terraplane |
| GM/Chevy Pickup power window switches | Stinkin_V8 | Electrical | 6 | 01-24-2009 08:42 PM |
| 95 Grand Am Power Window Motor Replacement | leejoy | Hotrodding Basics | 8 | 09-02-2007 07:55 PM |
| wiring a 3 switch kit for power windows?? | doncase | Electrical | 7 | 06-11-2007 09:24 AM |
| Junkyard power window retrofit into 2nd generation Nova | novajohnb | Interior | 4 | 11-16-2002 11:33 AM |
| EZ WIRING POWER WINDOW KITS | little marine | Interior | 1 | 12-11-2001 05:20 PM |
