F-1 bed wood coating - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2007, 04:34 PM
I need some advice on what to use to prep & coat the oak wood strips that I'm putting in my F-1 before the stainless strips tie them down. I've had several ideas and all are said to be the "best"! Oil stain, water based stain, varnish, shellac, etc. though one fellow says he used automotive clear coat on his teak strips on his boat & they are 6 years past & still look new! Any expert thoughts here??
Old 05-29-2007, 04:43 PM
shine's Avatar
Last journal entry: some progress
tongue oil by formby's works well.
Old 05-29-2007, 06:47 PM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
Would this article help?
http://www.mar-k.com/wood_finish_testing_i.html
I have not done any of them, but I bookmarked this a while back.
Old 06-01-2007, 11:50 AM
Thanks for the input. After digging around the past few days I'm going with Behr Tung Oil which is readily available here and likely similar to formby's. It won't peel & a coat every year is an easy upgrade.
Old 06-01-2007, 01:09 PM
shine's Avatar
i put 3 coats on the 56 big window i just finished. wan not new woo. had been varnished and it went away. but turned out nice after sanding and tounge oil. for a driver it is best. you can recoat with a rag.
What wood for truck bed? Nightfire Hotrodding Basics 17 06-16-2006 04:53 PM
wood bed kit OperationMidnight Body - Exterior 1 08-13-2005 09:19 PM
wood bed thickness question 70chevyc10 Body - Exterior 4 04-24-2005 09:18 AM
spray/brush in bed liner on wood? akm Interior 2 05-09-2004 09:43 PM
Replacing wood bed in '53 Ford P/U first timer Hotrodding Basics 8 12-12-2003 05:08 AM
