F 1 engine tranny swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2010, 07:39 AM
Hey all, I'm putting a 350 sbc with a 350 turbo trans in a 49 Ford truck. I'm setting the engine and trans in to fabricate the motor mounts. When I set the tail of the trans where I think it should be, the motor sits so low that the fan isn't close to be centered in relation to the radiator. When I raise the engine to get the fan correct, the tail of the trans seems pretty high. To get the trans to mount to the crossmember , I would have to have a really big spacer, or flip the crossmember over. I've seen sbc's in these trucks with the engines sitting high with the fan correct, but I don't know how the trans is mounted or if they had to modify the firewall . I've also seen them sit low, but it seems like the fan sits too low. Has anyone done one of these??
Old 11-27-2010, 07:57 AM
delawarebill's Avatar
motor mounting
for me i'd mount the motor where u want it.. put a level on the intake and level it with moving the tranny mount up/down.
don't forget u can always use an elect fan.. bill
1980 camaro z28 with a TH350.. swap tranny?? sexypizzaman Transmission - Rearend 4 03-11-2009 05:45 PM
engine and tranny swap on a 62 lincoln continental krazywayne Hotrodding Basics 12 01-29-2009 05:48 PM
2001 chevrolet engine and tranny swap gibsonballs1 Transmission - Rearend 1 11-24-2008 05:56 PM
75 F-350 engine, tranny swap loosebb Engine 1 09-05-2008 02:10 PM
