f-100 1982 oil leak HELP!!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2006, 09:23 PM
i have a 302 v8 and i cant quite found out where the leak is coming from. where the dip stick goes in it looks like thats it but oil is spaying all over the fire wall, and the back two spark plug wires on the driver side. any ideas
Old 05-04-2006, 10:01 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Do you have your dipstick in the tube?
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 05-04-2006, 10:03 PM
lookatme's Avatar
well,.............. best bet. get a rag, wipe down the block of the excess oil. run it with it in park, and look in that area. slowly raise your rpms till you find it. might be as simple as the oil dipstick is not in all the way, could be a leaky valve cover gasket, or something else, like a bad pcv valve.
best way to find it is clean it and look.
Oil leak at MSD distributor base? TVR383 Engine 2 10-28-2005 04:37 PM
oil filter leak Yub350 Engine 7 01-05-2005 12:53 AM
Oil leak fred56 Engine 2 12-13-2004 01:45 PM
Oil leak still?? leastbay Engine 8 08-15-2004 01:41 PM
Tip of the day on oil additives that you need to read mcgyver-ky Engine 10 04-19-2003 06:17 AM
