F-100 drop spindles - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2005, 09:43 AM
UNIBOMBER
F-100 drop spindles
I have a 63 f-100 unibody and I need a drop I-beam and/or drop spindles, I have a small oil pan to i-beam clearance issue, and I want it alot lower. I dont want to convert to M2 suspension, I'd like to keep it stock susp. Thanks
Old 03-04-2005, 09:28 PM
As one of the Moderators here.........let me be the first to WELCOME YOU !!
A dropped axle would be what you need......Maybe someone else has a source for one.......
Old 03-04-2005, 09:34 PM
speede5's Avatar
go fast, turn left!
I used to own a 66 Mercury M100 which is a canadian F-100. I used to see lots of ads in the custom truck magazines. Look for the ones with lowering kits for everything and you should find the droped I beams which is what you will need if you stick to your current setup. There are plenty available, I don't know about clearance to the pan but you could always notch the pan yourself.
s-10 & monte carlo drop spindles 406 ss monte Suspension - Brakes - Steering 6 04-09-2004 06:31 AM
Drop spindles and lowering springs scott ticknor Suspension - Brakes - Steering 1 11-25-2003 05:51 PM
Drop Spindles black66 Suspension - Brakes - Steering 1 08-07-2003 04:32 PM
67-72 drop spindles chevyman17 Suspension - Brakes - Steering 2 05-01-2003 05:40 AM
Should I use drop spindles? 57Chevyman Suspension - Brakes - Steering 6 12-12-2001 10:38 AM
