f-100 rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2005, 09:14 PM
f-100 rear end
does anyone know the gear ratio of a 1980 f-100 with a three on the tree? i put that into my '49 and i'd like to know the gear ratio of it. also what would be a good tranny to put into it that would give me the most power and acceleration with my flathead?
Old 09-11-2005, 09:19 PM
poncho62's Avatar
Wiki Edits: 5
Probably came in a variety of ratios..................jack the car up and check how many revolutions the driveshaft turns with one revolution of the tires.
Old 09-11-2005, 09:35 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
most likely it's a 3:00 rear. or real close to it....
Old 09-11-2005, 10:59 PM
redlightning's Avatar
Here is a good article on the subject. http://www.ford-trucks.com/article/i...ial_Swaps.html
Old 09-20-2005, 03:58 PM
Rev It Loud, Drive It Proud!
check to see if there is a tag on one of the studs holding the carrier in place. on the bottom left of the tag there should be 3 numbers on it (ex 3 00) and if it is a limited slip there will be an L in there (ex 3L00)
Thump Thump in rear end?? HotRodMan Suspension - Brakes - Steering 7 01-24-2007 07:09 PM
1975 8.5 rear end camino_man Transmission - Rearend 6 09-18-2004 06:32 AM
Rear End Change black66 Transmission - Rearend 4 01-28-2004 10:21 AM
Important rear end mounting question 71gtx Transmission - Rearend 2 01-04-2004 07:05 PM
Ford 7.5" Rear End Traction-Loc Install nightrain_rod Transmission - Rearend 2 12-30-2003 07:38 PM
