f-100 straight axle on a fenderless rod? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2008, 05:08 AM
anybody out there using an f-100 straight axle under a fenderless rod front end.......lotsa folks think they're an ugly piece as far as axles go,but they're pretty stout,and affordable......anyone got pics' of this application and how you went about it?......thanks for any input
Old 09-11-2008, 06:26 AM
BOBCRMAN@aol.com's Avatar
Tho I haven't used the F-100. i have used the Econoline.
By running two radius rods, bolted to the original spring mount, back to the frame. Then mounting a transverse spring behind the axle. Thru the radius arms. Suicide style. Works out well for a mid to heavy weight car.
Old 09-11-2008, 07:16 AM
345 desoto's Avatar
Location: Skaneateles, NY Summer/Port St.Lucie, FL Winter
BOBCRMAN,
Any pictures?...
Old 09-11-2008, 11:06 AM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Try this link for a look at the F100 suspension: http://www.classicperform.com/tech_a..._Steering2.htm
5.7" vs. 6" savman1 Engine 30 01-20-2006 09:17 PM
Rod ratio RobbieRat Engine 16 11-29-2005 06:52 PM
transverse spring & straight axle 26trackt Suspension - Brakes - Steering 3 01-18-2003 11:45 PM
straight axle falcon kalowry Suspension - Brakes - Steering 13 01-04-2003 03:26 PM
1938 chev - straight axle front end WILLARD(SONNY)STOTLER Suspension - Brakes - Steering 4 12-30-2001 03:26 PM
